Performed update on my RNS 510 Rev. A
Went from 3810a_noru to 4020 Modified
Used Verbatim DVD-R, burned with cdburnerxp, 4x speed and Track at once.
Enabled Downgrade in secret menu.
Made an hard reset and the I applied custom bootlogo.
Used TDK CD-R, burned with cdburnerxp, 1x speed and Track at once.
New bootlogo, VIM and HDD partitions as promised.
Loaded Western Europe v8 maps Speedcams Edition (cd 7692) to the HDD
Everything works! No problems at all!
Thanks alot!
Might be worth just trying a cd lens cleaner and see if that helps
Can someone please tell me what the difference between these 2 x 4020 versions?
This one is named 4020_a_B
& This one from the first page is named FW_4020_a_70_25_5
I have a EU unit bought on eBay and wondering which is best for my unit.
Volvo S60 RD T6
The "Euro" firmware versions have the HDD partitions set at 75/20/5 (Music/Map/POI)%
The Australian Firmware versions have 90/5/5% because our maps are significantly smaller in size (HDD space).
What version EU unit did you buy from eBay? The 4xxx links here are for A/B/C, and a second edition for the later version units (E/F etc). The older uniuts (A/B) are a little temperamental with the 4xxx series, so some tweaks were done to enable them to load.
FWIW...there really is no visible difference between 38xx aznd 4xxx...just e-penii bragging factor.
Hit me with any questions or requirements, and I'll point you in the right direction.
Just a note: the firmware in this this thread is for systems Physically located in Europe. Not those bought from Europe and installed in a car in Adelaide...
Use the thread for aus firmware if you are in Adelaide (or anywhere else in Australia).
I have moved my questions to the Aus/NZ thread as this is the more relevant thread! Sorry!
Last edited by thezoneR32; 06-05-2012 at 04:56 PM. Reason: Questions posted in wrong thread!
