Results 11 to 20 of 37
Thread: Which firmware for my RNS510?
    Jun 2009
    Around
    So I gather the firmware will fit on any version of the RNS510 then...
    MY09 Golf GTI Pirelli - 5DR - Black - Sat-Nav - Reverse Sensors - GIAC EXTREME TUNE
    Jul 2010
    Quote Originally Posted by pat25d View Post
    There is instructions/links on my-gti, I followed them and all good. Although it now thinks my C is a D.
    It's just an illusion!
    If it was a C before the upgrade, then it's still a C (despite what it says on the screen) after the upgrade.
    MY11 Tiguan 147TSI (SOLD)
    Jun 2009
    Around
    Well just burnt 3810 to a DVD-R and unlocked car and turned the unit on and put the disk in and it said reading disk and then gives an unreadable DVD/CD error message!!
    Any ideas??
    Quote Originally Posted by DJC View Post
    Any ideas??
    I had the same problem, have to burn the nrg file and mount as an ISO using nero. If that doesn't work try
    Using another DVD as the unit can be picky with DVD formats
    MY07 Jetta 147 TFSI 2.0 Auto | DSG | Sunroof | Leather | 18' Charleston Rims | Window Tints | Sat NAV RNS510 | Bluetooth
    Jul 2010
    Suggest you use the software called imgburn!
    Burn at slow speed also.
    Jun 2009
    Around
    That worked a treat!!
    Jan 2008
    Camperdown, NSW
    I'm on 2660. I have a Skoda Bluetooth 1Z0035729B. i notice all of the entries after 2660 have a warning about the bluetooth. Have people had any success or is it definitely not going to work?
    Do the newer versions change the screen colours or anything? There seems to be scant information about what the changes actually deliver.
    GTI | MY08 | Blue Graphite | DSG | Leather | Bi-Xenon | RNS510 |
    Jun 2009
    Around
    Added 3810 and now wife says that about every 4 minutes the radio stops working!!
    Any ideas??
    Jun 2009
    Around
    Reloaded the software with 3810 and the radio still switches off after about 6 or so minutes. Have had the radio lock up and also lose volume control. To fix it I had to disconnect the battery.
    Ive tried to downgraded but with no success.
    Can anyone help with the procedure to down graded and which is the most stable version to use?? I gather it is in the 2*** ranged of firmware!
    Thanks
    Jul 2010
    Mate ... I warned you in the very first reply you received in your thread!
    I also said FW 2760!
