Will take some pics for you tmozza![]()
Back of the rear seat for me with my amp.
There aint no space under them seats!
Couldnt tell you about the power cable. Had it done "professionally" *cough*.
I'll post'em up this arvo . . .
I knew i had a pic somwhere.
If you follow the looms down you will find where i entered the firewall.
Sweet.. thanks a lot Science VR6....
Alex I eagerly await your pics...
haha, damb im a lazy... . . .
The install, not that cosmetically pleasing but is all dead center of the car soze not lopsided . . .
Attachment 784
I've pretty much ran the power cable along with the factory loomz . . .
Attachment 785
as previously mentioned, theres a gromet up there, go through that . . .
Attachment 786
Attachment 787
Den there's another one tucked up in there that will grant you access into the cabin through your firewall . . .
Attachment 788
Hope it helps! and good luck
Laterzzz . . . Alex
I stuffed my 4 Gauge Power Cable cable down the side of the top strut tower next to the fender on the LHS of the car. I had to drill a hole in the rain shield for the cable and a grommet. Then ran the cable up the side of the pollen air filter box and I think another drilled hole and grommet. You will have to take the pollen filter box out to do the work. Then inside the car the cable pokes through the firewall at the far LHS behind the Airbag. I then run it down the kick panel between the chassis and the brackets for the dash. You then run it under the kick panel and into the lower door frame tunnel... this then exits under the rear seat and then you just feed it where ever to the rear where you mount your amps... I also did the same to the RHS of the car for my 3 pairs of RCA cables.
\( O ) o\====(\X/)=TDI=/o ( O )/ 2011 Jetta Mk5 125TDI - Squidly
((o)(O))====(\X/)=TDI=((O)(o)) 1996 Golf Mk3 TDI - Squid
