Originally Posted by
Gigitt
I stuffed my 4 Gauge Power Cable cable down the side of the top strut tower next to the fender on the LHS of the car. I had to drill a hole in the rain shield for the cable and a grommet. Then ran the cable up the side of the pollen air filter box and I think another drilled hole and grommet. You will have to take the pollen filter box out to do the work. Then inside the car the cable pokes through the firewall at the far LHS behind the Airbag. I then run it down the kick panel between the chassis and the brackets for the dash. You then run it under the kick panel and into the lower door frame tunnel... this then exits under the rear seat and then you just feed it where ever to the rear where you mount your amps... I also did the same to the RHS of the car for my 3 pairs of RCA cables.
