THanks for the PICs Glidn
But I am bit confused to what a door pod is, so this freshly made fibre glass .........
IS A DOOR POD??? So bascially you molded another door ??
OR this fibre glass is connected to the metal frame and door card is snapped back ontop ????
I think I really need to see the finished product to understand this.
On another note, today I cut an MDF ring for the 6.5" as a kick panel, I realise it is WAY too BIG, the "ideal" position for the kick is getting in the way in the the pedal.
So similarly to a kick position and most feasible/ economical way is to make a spacer to have the door speaker tilted, ie protruding out, aiming at passenger. DO you guys think this would work.. ??
I also played with the 4" at the kick position too, it sounded wrong at different axis to the 6.5" at the door.
So perhaps, mounting the 4" and 6.5" on same axial protruding on an angle at the door ????
