Originally Posted by
rayray086
How thick should the fibreglass and MDF be? I'm thinking of doing this myself one day too, this being inspiration
id say make your baffle out of some 16mm MDF just to be on the safe side, 12 mm just seems too thin to me
had alot of experience with this sort of thing and have found that 16mm is the way to go or even thicker (sandwich two sheets together with liquid nails) depending on what sort of power you are dealing with... the thickness in the fibreglass section you have made is not as critical however as its curves lead to a majority of its strength...
your fibreglass section looks fine, although its a little thin in some places, however again it depends on what sort of power you are going to be running...
keep it up, will look great when its finished
1999 MK4 GTi 1.8T - Custom Code Stg 1, ECS Stg 1, 14lb Fly, 18" A8's
''Jap cars pull the G-Forces... Euro cars pull the G-Strings...''
