You can only update the RNS when no key is in the ignition, you just hop in the car and manually turn the HU on and go from there.
If you didn't know that you can try updating again, otherwise a visit to the dealer might be needed.
yer thats what i gathered, i didnt have keys in just switched it on.
Think my issue is both trying to go to bigger jump in a firmware update, i should have done it in a few steps instead of going from the original to the most recent.
Think i need to try and find a solid firmware for a version A unit and just try install it, hoping it will bring the rns back to life
Maybe. Try installing version 26xx from the my-gti website.
All now sorted with a new loading of firmware. Only issue now is no steering wheel buttons are functioning and the mdf is not linked :S
Also when I try to copy from the sd card, I get this...
http://i58.photobucket.com/albums/g2...e/2c915e4c.mp4
Starts and then just drops away and the folders don't get copied..
Try doing the copy when listening to music on your HDD, I've not had your exact experience but I do lose a little functionality when trying to play and copy from the same source.
- You may not post replies
- You may not edit your posts
Forum Rules
