I did my RVC wiring the easy/lazy way haha.
Ran the wiring from the camera from outside the bumper, punched a hole and ran the wiring through the rubber plug on the back of the chassis (it comes out under the boot lining - if you take the bumper off you'll see it), up and around the the wall carpeting on the left side of the boot, past the rear seats, tucked it under the plastic trim (where the plastic trim and floor carpet) that runs the length of the inside, followed that all the way, under the glove box (again, between the plastic trim and the carpet), up to the left side of the centre console, then found a spot to push through between the console panels and up into the headunit hole.
It took a bit to get it all tucked away and hidden, and to grab the cables pulled up into the headunit hole, but it was way easier than taking any of the interior out.
Hope that makes sense?
