Results 11 to 20 of 26
Thread: ebay rns510's
    NSW, Sydney
    i just looked at your seller and he has none left
    Jul 2010
    Hi Robbie,
    I had to message him for the second unit and he said he had 3 left. So not too sure whether you pm in and asked for it?
    Jan 2011
    I used a guy from the UK. Version c LCD bit more expensive than competitors but it comes with everything you need and 12months warranty.
    It's been great so far. Only little problems is I haven't been able to code in the steering controls yet or the mfd turn by turn display.
    Jul 2009
    I bought Version C with the LCD. All my trials & tribulations here
    My steering controls worked straight away as did the integration with the MFD. I've just returned from a 10 day trip and there were no battery drain issues either. Car started perfectly.
    Skoda Octavia Mk3
    (sold) Golf Mark 6 Comfortline 118
    (sold) Golf Mark5 Comfortline Manual 2.0 FSI
    Jan 2010
    Pacific Pines, Qld
    Hi Can, you let me know what version you got for example:
    Part number: 1TO 035 680 C
    Hardware stand: H41
    Software: 2720
    Thanks
    Petho
    Jul 2010
    Quote Originally Posted by petho View Post
    Hardware stand: H41
    Software: 2720
    Thanks
    Petho
    Hi Petho,
    Partnr: 1T0 035 680 C
    / H42
    / SW2720
    FAQ » RNS510 Hardware was steckt in ihm? and this one
    http://187509.homepagemodules.de/t7f...heinungen.html
    You might have to get it translated via Chrome or any other sites that you use.
    Melbourne, Victoria
    several people say it takes áges' for these to initially lock on. Mine has been on 40mins without locking on. All other features work. The GPS status page says 0/12 and sometimes 0/13 satellites. It has a wrong location from europe shown (and changes it slightly when car driven - obviously trying to fudge dead reckoning). I suspect it is confused because it has just moved around the earth as it can see the # of available satellites.
    I have double checked antenna and it looks fine i.e. is plugged in. Anyone got any tips? ANy way to force it onto a new search from the start?
    Golf VII GTI MY 14 (Post my VI Adidas GTI being written off)
    Melbourne, Victoria
    OK All going now.
    With a fair does of Google, I found out that by holding down Setup when turning on, it seemed to trigger it into an initialisation mode. Suddenly it started finding satellites, and all was working in a few minutes. Using the Setup menu when it was on, and doing a resent of Nav etc didn't do anything.
    Anyway works well (also DVD, compass etc etc). with no VCDS coding it works fine. Voice commands on the rns work (not that I want them to). I think the only thing I am missing is the turn by turn directions on the FD. If VCDS can ever decode the CAN on this MY11 Golf, I will have a go (right now it says there is limited support!).
    One thing I aren't clear about is Voice Turn announcements. If one has the radio on they are too quiet to be clearly heard - can one adjust this?
    Jul 2010
    Robina Gold Coast
    Yes you can set the audio /radio /cd to lower volume when the gps is announcing turns its in the set up i think
    IN2VWS Guest
    I have found that if you adjust the volume while an announcement is being made, it gets louder.
    I am disappointed that the gps/NAV system does not show an actual GPS speed.
