Results 1 to 10 of 11
Thread: Dynaudio Amp
    Apr 2011
    Dynaudio Amp
    Hi all,
    Recently installed a dynaudio amp 3C8035456C from a Passat CC into my R36. Amp was a simple plug and play and the difference in sound quality is quite decent.
    My question however is that now when I do a VCDS scan it comes up with the below error. I assume this is because of an incompatibility with the CC amp.
    Only VCDS change I have done is enabling dynaudio. All this has done is bring up the logo on startup.
    Any suggestions on getting rid of the error code as apart from this it works well.
    Address 47: Sound System Labels: 3C0-035-456.lbl
    Part No SW: 3C8 035 456 C HW: 3C8 035 456 C
    Component: DSP 10 Kanal 0070
    Revision: 00H05001 Serial number: 75805000534103
    Shop #: WSC 00000 000 00000
    VCID: 2855E3919B3BBC58495
    1 Fault Found:
    00003 - Control Module
    014 - Defective
    Freeze Frame:
    Fault Status: 01101110
    Fault Priority: 5
    Fault Frequency: 1
    Mileage: 27925 km
    Time Indication: 0
    Date: 2031.14.03
    Time: 17:41:06
    Freeze Frame:
    Raw, Form. N/A: 000 000 000
    Apr 2008
    If it all works, why worry? I have a similar issue with the Skoda BT in the Jetta. Everything works as it should, but get a couple of errors thown when it scans. To me it's not an issue.
    Graphite Blue TDI| DSG | Leather | Bi-Xenons | Custom LED inner tails | Black Forest TAI | OSIR Pod & New South Boost Gauge | Bluefin | Projector Fogs | RNS510 | Skoda Bluetooth | Eibach Pro kit Springs| Full LED interior|US GLI paddle shift MFSW|Carbon Vinyl wrapped trims|Colour Coded Votex Body Kit|
    Apr 2011
    Quote Originally Posted by Buckets View Post
    As long as it doesn't cause any other issues, just though it might be a coding problem.
    Aug 2011
    It might be freaking out that it isn't seeing passat hardware. Also have you changed your radio coding to Dynaudio (CAN)?
    May 2011
    QLD
    Wasn't there a way to change the output of the RCD/RNS from speaker output to line output? Would you need to change that when using the Dynaudio amp?
    Apr 2011
    Have changed radio coding to Dynaudio and already had speaker to line output as it alreday had a factory amp (3C0035456K)
    Any suggestions?
    Aug 2011
    Quote Originally Posted by R36 DSG View Post
    Any suggestions?
    I haven't personally had a chance the fiddle with the VW sound systems, but I know there's two different Dynaudios one with BAP/CAN and one without. Have you tried both (In radio settings)?
    Apr 2011
    Quote Originally Posted by readerr0r View Post
    Sure have, the BAP does not work (no sound), so have it on dynaudio
    Jul 2009
    QLD
    Sorry wrong post
    2017 MY18 Golf R Wolfsburg | Oryx White | DSG / 2021 MY21 T-Cross Style | S+V Package | Limestone Grey
    Apr 2011
    Update,
    had to swap back the original amp as with the CC dynaudio amp the sound would keep cutting out. A reboot would occasionally bring it back but the next time I start up the car the sound would be gone again.
    Before I get rid of the amp, can anyone suggest any coding changes that may fix my problem otherwise I'll have to try and find the equivalent Passat amp.
