Results 1 to 7 of 7
Thread: Dropped a screw (!)
    Sep 2011
    St. Kilda, VIC
    Dropped a screw (!)
    I just installed my RNS-510, got the v4 maps on there and enabled ViM, and it's all super-pimp!
    ...BUT...
    I dropped a screw when putting the Climatronic controls back in, and it went down into the centre console somewhere
    I heard the little bastard bounce all the way down, like it was taunting me.
    Has this happened to anyone else, and if so how in the hell did you get it out without pulling the whole car apart?
    2011 VW Golf 103TDI 2.0L Comfortline
    Tinted | RNS-510 | Bluetooth | MDI | Reverse Camera (Highline) | (more-to-come!)
    -= I have a VAG-COM cable. Message me if you need help! =-
    Mar 2009
    UMG Brisbane
    Did exactly the same thing yesterday (installing BT) into the dash top vent.
    Amazingly, I did get it back after a few minutes jingling an old HDD (or similarly strong) magnet on a piece of string down the vent.
    Where exactly did you drop yours? Into the trans tunnel part? Might be too much metal to try that trick. Guess you can always see if it is wedged somewhere (in which case forget about it, get another one) or rattling (in which case, um, pull the car apart)
    Oh, and note that it is a good idea to close the dash top vents before removing screws.
    Al..
    2013 MY13.5 Passat V6 Highline Wagon. Watch this space
    GONE:2017 MY18 Skoda RS169 Wagon w/ Tech & Lux, 2007 VW MKV Golf GTi
    Sep 2011
    St. Kilda, VIC
    Yeah... it dropped down into the trans-tunnel part
    There are a few ideas I've read about, like removing the shifter-cover and removing the little pop-up box and getting in through there. Your magnet-on-a-string idea will definitely be worth a try though!
    Mar 2009
    UMG Brisbane
    It works where there is not a lot of metal - you don't want to end up with a magnet stuck down there too...
    Apr 2010
    I dropped one the last time I had my RNS out (was probably installing the MDI or something). Just left it as is and haven't heard anything or noticed anything different visually. Don't sweat about it too much
    Sep 2011
    St. Kilda, VIC
    So... I got it out! It was all the way down, nearly directly below the gear-shift.
    Took me about 40 minutes to delicately pull the centre console apart and find it, then another 30 to get it all back together... but I am glad to have it out of there.
    It's actually a good bit of practice and knowledge getting the whole thing apart and back together, for potential future upgrades... especially ones that require a switch in the centre (near the TCS button).
    Apr 2010
    Kudos to you for pulling that all apart just to retrieve a screw. I couldn't be bothered removing that to change to the GTI-style DSG shifter
