I'll email you the repair guide.
Once you crack open the LCM which is bolted to the headlamp, you should be able to probe the guts and hopefully find something that you can solder on a wire to run a relay off...given that LEDs are voltage rather than current devices, hopefully pulling a small current off a circuit to run a relay won't upset the LCM to the point where is logs a fault....maybe??
