Page 102 of 106 FirstFirst ... 25292100101102103104 ... LastLast
Results 1,011 to 1,020 of 1059
Thread: DNS series head unit (new generation dual core RNS-510 alternative)
  1. #1011
    Quote Originally Posted by asa572 View Post
    with the last update, has anyone else had problems with the bluetooth?
    Mine will not automatically connect to my phone.
    where as previous versions would connect.
    I haven't had any issues, maybe try deleting the BT connection from your phone and re pairing?
    Quote Originally Posted by allypally View Post
    Have the DNS810 (From Sandy's group buy). When connecting the iPhone 6plus via the usb port on the DNS the following error is displayed. The iPhone will not charge or interact with the DNS. Anyone know what the issue is?
    Attachment 18363
    A translation from a fried was "unidentified USB object"
    The firmware I have is
    Attachment 18364
    It doesn't work like that. You can't plug directly to the USB port for an apple device. To use an apple device, you must use the 30pin connector. So for lightning devices you just also have a lightning to 30pin adapter. Genuine only, I've seen heaps of people have issues with 3rd party adapters.
    MY10 Golf Mk6 103TDI DSG Candy White | Revo Stage 1 ECU Tune | 18" Talladegas | GTI Front/Rear/Exhaust | R LED Taillights | GTI Steering Wheel | VW Discover Media | Focal IFVW Front Speakers | Mk7 Climatronic Panel |
  2. #1012
    I use a genuine 30pin/lightning adapter on my iPhone 6 without any troubles. I get the same error if I try and use the USB connector.
  3. #1013
    Quote Originally Posted by Scratchedeos View Post
    Yea, because almost no headunit (such as the DNS) is MFI certified and works like that.
  4. #1014
    Jun 2008
    Wollongong, Oz
    Thanks guys. Will use the 30pin connector. Just tried the USB connector on my Samsung Note (Android) and got the same error.
    MY22 Tiguan 162 Elegance
    Sound and Vision , Sunroof packages
    Fireball Graphene Butterfly ceramic coating
    Thinkware U1000 dash cams
  5. #1015
    Yep, the USB input only works with USB MSC (Mass Storage Class) devices, ie, HDDs and USB sticks.
  6. #1016
    Aug 2011
    Lake Macquarie
    Quote Originally Posted by moda View Post
    Tried that Moda and it still won't pair automatically.
    Maybe it the new phone.
    I will try my old one and see if it works.
    MKV Sportsline Soot Belcher
    MKV Jetta FSI DSG
  7. #1017
    Oct 2012
    Since last update I'm having issues on startup.
    If starting with radio the sound is muted and I need a soft reset to return to normal.
    When reversing, graphic goes to reversing camera however I don't have a camera installed.
    Sent from my SM-G850Y using Tapatalk
  8. #1018
    Sep 2008
    Melbourne, Australia
    Try completely removing the phone from the units memory, rename it and load again.
    Prev 2008 R32 3 door DSG.
    Prev 2010 S3 Sportback Stronic.
    Now Lexus IS350 F Sport
  9. #1019
    I recently upgrade the operating system in my iPhone to ios9 and now my Mirror Link does not work. The option has disappeared on my phone. Has anyone else had this problem?
  10. #1020
    Jul 2015
    South Africa
    Quote Originally Posted by Fdandy View Post
    Same story, the graphic also changes to the one with a reverse camera rather than the OPS graphic. I updated quite a while back as this only happened way after that....any suggestions???
    Thanks guys!
