Page 98 of 106 FirstFirst ... 488896979899100 ... LastLast
Results 971 to 980 of 1059
Thread: DNS series head unit (new generation dual core RNS-510 alternative)
  1. #971
    Jul 2015
    South Africa
    Quote Originally Posted by Goobz View Post
    The version I am running I posted here:
    Not 100%if it's the "latest", but it's running great for me (MKV GTI)
    Just make sure you flash the correct MCU or you will brick your unit.
    Thanks again Goobz
    My current version is ;
    BSP: MS9.H.32.1018
    MPEG:
    MCU:
    DNS810.A.1010
    BT:031407180
    MPUNS810.13Nov14.32.VW.V41
    CAN:VW_V02.27
    MAP:
    SOFTWARE:
    So mine has the "A" type.
    So I follow this first : https://dl.dropboxusercontent.com/u/...A_20150326.zip
    then I do this one: https://dl.dropboxusercontent.com/u/.../VW_V02_32.ihs
    Is this correct???
    Also I am based in South Africa (not sure if updates is area specific)
  2. #972
    Quote Originally Posted by badboy4life View Post
    Thanks again Goobz
    BSP: MS9.H.32.1018
    MPEG:
    MCU:
    DNS810.A.1010
    BT:031407180
    CAN:VW_V02.27
    MAP:
    SOFTWARE:
    Is this correct???
    Read this: https://docs.google.com/spreadsheets...8n4/edit#gid=2
    AND
    this: https://www.dropbox.com/s/75l4keuonl...ANBUS.doc?dl=0
    BEFORE YOU DO ANYTHING!
    Also read and follow Goobz post here: DNS series head unit (new generation dual core RNS-510 alternative)
    Use the 'A' firmware and the .ihs file ONLY.
    As everyone has said, new firmware should fix your issues, but it is your responsibility to read all the instructions and follow them, it is up to you to follow them, otherwise you will brick your unit. THIS IS YOUR RESPONSIBILITY.
    ALSO, do it with the engine running to make sure your car doesn't drain the battery, AND if the unit freezes or doesn't do anything or just has a black screen throughout the process, JUST LET IT SIT AND DO ITS THING. DON'T PANIC. DON'T TOUCH IT. LET IT DO ITS THING.
    MY10 Golf Mk6 103TDI DSG Candy White | Revo Stage 1 ECU Tune | 18" Talladegas | GTI Front/Rear/Exhaust | R LED Taillights | GTI Steering Wheel | VW Discover Media | Focal IFVW Front Speakers | Mk7 Climatronic Panel |
  3. #973
    Jul 2015
    South Africa
    Thanks Moda
    Really appreciate the assistance
  4. #974
    Jun 2012
    Hi Everyone,
    Been viewing this thread for a while!
    I have recently purchased a DNS810 directly from AS. I have not gone down the firmware path yet as I wanted to make sure I didn't have a faulty unit before starting. I have always had FM radio reception issues. When I first got it I didn't have the correct antenna plug so i plugged in one of the antennas and waited a few weeks for an antenna adapter to arrive. Now that I have the adapter in place with both antennas connected, the reception has not improved much.
    When I say reception issues - the problem I see is that I get occasional static and sometimes it jumping between stereo and mono reception. Some stations are better than others, that said the old head unit never had the same issues in the same locations.
    Has anyone had a similar issue?
    Can anyone confirm if FM reception was addressed in any of the firmware updates?
    This is my current firmware
    DNS series head unit (new generation dual core RNS-510 alternative)-img_20150603_080629-jpg
  5. #975
    Thanks Moda
    No worries mate, let us know how you go
    Quote Originally Posted by jimmej View Post
    Hi Everyone,
    What sort of radio reception issues? In my experience, the DNS has substantially better radio reception than any other chinese unit, and is on-par with the factory units. Sounds like you had the 2xsingle fakras instead of the dual fakra plug? I think you'll find one of the plugs is for AM and the other is for FM.
    Firmware doesn't address reception, it is what it is. I'd highly recommend updating the firmware though, everything is a lot better since the one you have.
  6. #976
    Jun 2012
    Quote Originally Posted by moda View Post
    Thanks for a response Moda. Yes I have the 2xsingle FAKRAS. The reception has static that comes in and out at time. Volume can be all over the place too as i think as reception degrades it starts turning the signal off. I would have thought the radio is software defined and hence firmware could improve it but it seems that you have not heard of any issues here so a firmware update probably won't help. AM works fine. I guess it's possible that the antennas are swapped. I have read that the OEM radios choose between the two antennas to find which is best. Maybe the DNS doesn't do this?
    One thing I am considering is if the wireless reverse camera is interfering by inducing noise onto the antenna. Changing this requires pulling apart the dash unfortunately. Something I am getting better at each time...
  7. #977
    Jun 2012
    So I noted today that the radio reception is only bad when the car is on. Magically comes good when the car is off. I probably have a loose ground. Hopefully get a chance to investigate it soon.
  8. #978
    Dec 2012
    Yep sounds like a bad ground somewhere to me. Looks like you have some time with a multimeter ahead of you!
  9. #979
    Feb 2015
    Russia
    Maybe bad charger is plugged on and start to work than car is on?
  10. #980
    Jun 2013
    Are you back up and running again Moda, how long did it take to get the part from China from when you ordered it?
