Page 97 of 106 FirstFirst ... 47879596979899 ... LastLast
Results 961 to 970 of 1059
Thread: DNS series head unit (new generation dual core RNS-510 alternative)
  1. #961
    Jun 2013
    Quote Originally Posted by Kakourgos View Post
    I have no idea yet of what has been improved in this version. What i noticed though is that the AUX input (analog) using the AUX in plug in the center console arm rest is now working when -from what i remember- i tried a couple of times with the previous SW and it didn't work.
    Can somebody confirm this?
    I'm on 2.27 and I know that my aux-in isn't working. (I had always that it was because the installer didn't plug it in properly)
    If 2.32 enables aux-in, then it could make it worth taking the risk to upgrade!
  2. #962
    Quote Originally Posted by chrislewis85 View Post
    Hi guys,
    Can anyone confirm newest available firmware version for my 'pre-release' DNS unit (without 'new' CAN chip)? Not sure if most recent link is applicable to my unit or not.
    Current version:
    Shoot Sandy an email to check, I could hazard a guess but don't want to risk it :p
    Quote Originally Posted by MacinJosh View Post
    So does anyone know the advantage of updating CANBUS firmware from 2.27 to 2.32?
    No idea on the specifics, but the updates on the CANBUS are typically fairly incremental. No reason not to run the latest, though.
    Quote Originally Posted by matiasg85 View Post
    HI, have anyone tried the D90-810
    Professional bmw car dvd manufatuer
    I'm thinking on give it a try, my main concern is the sound quality.
    Here's a video
    Hardware should be pretty much identical to the DNS, so would expect it to be the same.
    Quote Originally Posted by sneaky View Post
    Hey guys,
    Just looking at upgrading my headunito to a DNS 610 or 810 as i dont ned to fork out extra money for the bluetooth and GPS which i dont use to often anyway but always a bonus.
    Just one query i hope someone can answer is that with the bluetooth audio streaming do the track and artist details display on the headunit / MFD?
    Jared
    Nope, sorry mate. No track info via BT streaming in the DNS on the MFD, as Kakourgos said. VVV
    Nope,
    I should also mention that i cannot use the buttons on the wheel (MFW) in order to skip next/previous/play/pause track when in A2DP mode.
    I have to use the audio player buttons on the screen or the hardware buttons of the unit.
    Quote Originally Posted by swong View Post
    I had aux-in way back with my original preproduction unit working, as far as i'm aware it's hardwired into the iso harness, not sure why it would be disabled in firmware though.
    MY10 Golf Mk6 103TDI DSG Candy White | Revo Stage 1 ECU Tune | 18" Talladegas | GTI Front/Rear/Exhaust | R LED Taillights | GTI Steering Wheel | VW Discover Media | Focal IFVW Front Speakers | Mk7 Climatronic Panel |
  3. #963
    Dec 2014
    Athens, Greece
    The build in microphone of my DNS doesn't perform that good.
    Now, what are the options that we have to improve it?
    In my opinion the best solution should be to use a microphone in the factory position close to the middle mirror.
    I have collected the required parts for factory installation (only needed part is a single or dual core -shielded- cable).
    If i find enough free time during the weekend i will do the cabling/installation.
    My questions are:
    Has anyone else done it before?
    Is the DNS prepared to accept an external microphone is the factory expected pins in the back of the unit?
    If yes then everything will be quite easy, if not i will have to rewire the internal microphone wiring -probably using a different/longer wire- leaving the internal microphone unused.
    The cost of the parts for me was about 15€ for the plastic connector holders and pins (repair wire) and about 10€ for the OEM microphone for ebay.
    I asked the local VW but they wanted about 60€ for the ~1€ production cost microphone….
    If the results are not that good i will also consider using the soon removed build in microphone. Even i could try other electret microphones from the local market as their cost is almost nothing.
    In any case i will proceed hoping that i will not have to open the unit.
  4. #964
    My questions are:
    Hey mate, I'm fairly certain the DNS doesn't have inputs for an external mic. Chances are you'd have to unsolder the onboard one and solder on wires for a new one. Too much effort for my liking, tbh.
  5. #965
    Jul 2015
    South Africa
    Hi guys
    Brand new to this website
    I know that this is an old thread but
    would really appreciate some info
    I just recently installed a DNS810 into my
    golf 6 gti 2012.
    I have been having endless problems with battery drain
    I have emailed audiosources for advise...no reply
    see below for system info on
    dns810 unit
    BSP: MS9.H.32.1018
    MPEG:
    MCU:
    DNS810.A.1010
    BT:031407180
    MPUNS810.13Nov14.32.VW.V41
    CAN:VW_V02.27
    MAP:
    SOFTWARE:
    I
    am based in Gauteng, South Africa. Any solutions to the battery drain issue will
    be highly appreciated..
    Thanks
  6. #966
    Aug 2011
    Lake Macquarie
    I have a MKV and have battery drain issues also.
    When I can be f'd I will be putting a new canbus in it to see if that helps.
    But in the mean time, if I am leaving the car parked for longer then a day I turn the head unit off before I turn the car off.
    This is the only way I can get my battery to last longer then a day sitting and the battery isn't that old.
    MKV Sportsline Soot Belcher
    MKV Jetta FSI DSG
  7. #967
    Dec 2012
    I had battery issues (MKV) until I updated it to the latest version (firmware + can) I got from sandy and haven't had a problem since. Have you guys tried the update?
  8. #968
    Dec 2014
    Athens, Greece
    After I installed the DNS, i donated my long serving RCD510 to my wife’s brother who has a 2005/2006 Skoda Octavia5.
    From day one he experienced power drain issues due to “old” can GW module.
    Using my VCDS cable and the information below we found that the can module could be SW upgraded to a compatible version (e.g. from 0110 to 017 ) .
    http://wiki.ross-tech.com/wiki/index...)_Retrofitting
    A quick visit to the main Skoda service and a 5-10’ procedure fixed everything avoiding the hassle of purchasing and installing a new can bus module.
    I believe it worth it to check if your current can GW can be SW upgraded to a version.
    I just want to point out that the issue is related to the Can GW and not to the DNS/RCD/RNS although it has been mitigated by SW changes in RNS/DNS.
  9. #969
    Jul 2015
    South Africa
    Hi Goobz
    Any idea what is the latest and most stable update??
  10. #970
    Dec 2012
    Quote Originally Posted by badboy4life View Post
    Hi Goobz
    The version I am running I posted here:
    http://www.vwwatercooled.com.au/foru....php?p=1128341
    Not 100%if it's the "latest", but it's running great for me (MKV GTI)
    Just make sure you flash the correct MCU or you will brick your unit.
