Page 72 of 106 FirstFirst ... 2262707172737482 ... LastLast
Results 711 to 720 of 1059
Thread: DNS series head unit (new generation dual core RNS-510 alternative)
  1. #711
    Oct 2014
    spain
    Quote Originally Posted by moda View Post
    Yea mate sounds like it hasn't flashed properly. Do you have a record of what was previously installed? Did you read all the instructions and confirm what version you were supposed to flash?
    sorry .... that originally had:
    BSP:MS9.F
    MPEG:
    MCU: DNS810.140114_01
    BT: 20120512
    MPU: DNS810.9005AS.20131220_16Bit
    CAN: VW_HW_3013110791
    MAP:
    SOFTWARE
    I fail with this version back and slow camera in navigation
    now with the upgrade in October many failures
    tnx
  2. #712
    Quote Originally Posted by lucas__ View Post
    BSP:MS9.F
    MPEG:
    BT: 20120512
    MAP:
    SOFTWARE
    tnx
    MPU hasn't installed properly, that's why. mixing 16 and 32bit = bad.
    You need to reinstall, following the instructions.
    Edit: sorry, misread, still think you flashed incorrectly anyways.
    MY10 Golf Mk6 103TDI DSG Candy White | Revo Stage 1 ECU Tune | 18" Talladegas | GTI Front/Rear/Exhaust | R LED Taillights | GTI Steering Wheel | VW Discover Media | Focal IFVW Front Speakers | Mk7 Climatronic Panel |
  3. #713
    Sep 2014
    Christchurch NZ (ex Brisbane)
    Reflashed on Sunday - Improvement noticed:
    The head unit now actually makes a ringing sound on incoming call when phone connected via Bluetooth - yae previously was muting sound intermittently, the other end of call could hear me fairly clearly.
    Call quality is improved
    Stereo/radio info on MFD - Mint
    Steering wheel buttons now work and "OK" button toggles between stereo functions
    Can change the time for the headunit - YAE
    Bad bit:
    Still cant change station presets when it has been saved to a place
    More intense testing at some stage when I get my hands on the car again =======>>>> Wifey....
  4. #714
    Quote Originally Posted by subieboy View Post
    Bad bit:
    Nice Can't remember if you had the original or the new revision?
    Either way, also noticed better BT quality, music streaming still isn't great, but its better. Haven't noticed the change in MFD/steering wheel buttons, but then again have been busy with uni :p
  5. #715
    Oct 2014
    spain
    Can anyone confirm whether any upgrade from usb rear screens work?
    tnx
  6. #716
    Aug 2011
    Lake Macquarie
    Things I have notice with latest update on my 610
    Good:
    RDS seems to be working properly (never has on mine)
    Disc button know works (has never worked)
    Usb loads faster
    When you start the car and stick it straight into reverse where it use to take 20+ seconds for anything to start,
    it now does it in around 5.
    When listening to USB and you have it set to random, if you shut the car off it always reverted back to repeat (Factory set),
    it now remembers the setting that you had it on.
    MKV Sportsline Soot Belcher
    MKV Jetta FSI DSG
  7. #717
    Sep 2014
    New revision
    Also to clarify: the "OK" button allows you to scroll through the various menu's of the stereo from the car's steering wheel incl Nav, Disc, USB etc
  8. #718
    New revision
    Ah yea, nice. My old rev doesn't do that. Keen to get on the new canbus chip.
    tnx
    No idea mate, i'm pretty sure you're the only one actually using the feature, most people wouldn't use it. Might be worth sending Audiosources an email, they may not even be aware of the fault.
    Quote Originally Posted by asa572 View Post
    Good:
    Usb loads faster
    Yep, pretty much my experience too, working really well. RDS still doesnt show up properly on MFD though, it just shows 1 letter, but probably a CANBUS limitation more than anything with the old decoder. BT is a lot better as well, from what i've ntocied.
  9. #719
    Aug 2011
    Lake Macquarie
    I have the half MFD so all the MFD problems don't bother me.
    They still need to do something about the equalizer.
    Loud doesn't mean add BASS
    And Ihave to try Sygic and see if it will work on my unit now.
    MKV Jetta FSI DSG
  10. #720
    Aug 2011
    Lake Macquarie
    Sygic still will not work in my unit.
    It works once but then loses unit ID.
    Tried Igo and the lag is still there but no where near as bad as it has been.
    MKV Jetta FSI DSG
