MY10 Golf Mk6 103TDI DSG Candy White | Revo Stage 1 ECU Tune | 18" Talladegas | GTI Front/Rear/Exhaust | R LED Taillights | GTI Steering Wheel | VW Discover Media | Focal IFVW Front Speakers | Mk7 Climatronic Panel |
Reflashed on Sunday - Improvement noticed:
The head unit now actually makes a ringing sound on incoming call when phone connected via Bluetooth - yae previously was muting sound intermittently, the other end of call could hear me fairly clearly.
Call quality is improved
Stereo/radio info on MFD - Mint
Steering wheel buttons now work and "OK" button toggles between stereo functions
Can change the time for the headunit - YAE
Bad bit:
Still cant change station presets when it has been saved to a place
More intense testing at some stage when I get my hands on the car again =======>>>> Wifey....
Can anyone confirm whether any upgrade from usb rear screens work?
tnx
Things I have notice with latest update on my 610
Good:
RDS seems to be working properly (never has on mine)
Disc button know works (has never worked)
Usb loads faster
When you start the car and stick it straight into reverse where it use to take 20+ seconds for anything to start,
it now does it in around 5.
When listening to USB and you have it set to random, if you shut the car off it always reverted back to repeat (Factory set),
it now remembers the setting that you had it on.
MKV Sportsline Soot Belcher
MKV Jetta FSI DSG
Ah yea, nice. My old rev doesn't do that. Keen to get on the new canbus chip.
No idea mate, i'm pretty sure you're the only one actually using the feature, most people wouldn't use it. Might be worth sending Audiosources an email, they may not even be aware of the fault.
Yep, pretty much my experience too, working really well. RDS still doesnt show up properly on MFD though, it just shows 1 letter, but probably a CANBUS limitation more than anything with the old decoder. BT is a lot better as well, from what i've ntocied.
Sygic still will not work in my unit.
It works once but then loses unit ID.
Tried Igo and the lag is still there but no where near as bad as it has been.
MKV Jetta FSI DSG
