Page 71 of 106 FirstFirst ... 2161697071727381 ... LastLast
Results 701 to 710 of 1059
Thread: DNS series head unit (new generation dual core RNS-510 alternative)
  1. #701
    Jun 2011
    Quote Originally Posted by 551704 View Post
    More forgot to say. Manager of Audiosources told me that they did not change can bus chip. and set that everything is the same. Here is her answer - About the chips, we always use the Japanese Shinwa chip as car standard line chip, dear, pls kindly note.
    They definitely did, the new CAN-Bus model is named DNS 610+ / 810+ now, ask your contact about it. Also when you say "her answer", you are not talking to the manager of Audiosources. The manager is male and does not speak English.
    I installed the old firmware because the latter worked very unstable. Besides the cold weather in Russia, and the device was loaded with 10 times. On December firmware today DNS610 booted immediately. Primo works really fast!
    When you say cold weather, I wonder if you got a pre-production batch of units - did you get your unit around December last year / January?
    I suspect the December firmware you are talking about is the 16bit version. 16bit is less CPU-intensive so things might feel smoother, and maybe the old pre-production units like 16bit better. However Primo still has issues when SD / USB is running in the background while Primo is running with the 3D map moving on the screen. If you are sitting in your garage fiddling with it without simulating a navigation route you should not have any issues with Primo. Alternatively if you have radio in the background (instead of SD or USB) you should also not have any issues with Primo even when driving / navigating.
    Anyway I will need to do some testing of the latest firmware version. About time they implemented the timezone option, I've been asking for it since I started testing Sygic months ago.
  2. #702
    Quote Originally Posted by DkN View Post
    ^ This. Also, as evidenced by the fact that Sandy has had both units, and the software is forked into 2 versions now, Old canbus and new canbus decoders. I even have the files to prove it.
    Finished with uni now so can/will upload new firmware for everyone, if ya'll want. Working fine so far, no issues *shrugs*
    Anyways, probably nap time now though :p
    MY10 Golf Mk6 103TDI DSG Candy White | Revo Stage 1 ECU Tune | 18" Talladegas | GTI Front/Rear/Exhaust | R LED Taillights | GTI Steering Wheel | VW Discover Media | Focal IFVW Front Speakers | Mk7 Climatronic Panel |
  3. #703
    Jan 2013
    Cool would that be for the old canbus version?
  4. #704
    Quote Originally Posted by cpkk View Post
    October 2014 DNS Firmware for both old and new CANBUS models. You absolutely *MUST* read the instructions before installation.
    Old CANBUS = MCU version string DOES NOT CONTAIN the letter "A", CANBUS version is "VV_HW_3013110791"
    New CANBUS = MCU version string contains the letter "A", CANBUS version starts 'VW_V02'
    CONFIRM AND READ INSTRUCTIONS BEFORE FLASHING.
    https://www.dropbox.com/sh/zko8wev0v...1w_xZyKJa?dl=0
    Might take a while to upload, sorry about that.
  5. #705
    Jun 2014
    Rybinsk
    Hello. Sorry for my bad English - translation difficulties. I bought my DNS610 in June 2014. The firmware version was dated December 2013. The manager, with whom I spoke name is Lisa. Did I correctly asked her about the change module CANBUS, so got the wrong answer. The meaning of my next posts - with all firmware other than December 2013 my DNS610 bad start in the cold
  6. #706
    Oct 2014
    spain
    installed the latest firmware .....
    many problems:
    reversing camera does not work.
    sound driver door without bass.
    you go crazy when you want to open ..... being closed.
    GPS does not work ........ does not start ......
    etc ....
    last:
    BSP: MS9.H.32.1018
    MPEG:
    MCU: DNS810.141014
    BT: 20120512
    MPU: DNS810.11Oct14.32.vw.v36
    CAN:
    MAP:
    SOFTWARE:
  7. #707
    Quote Originally Posted by lucas__ View Post
    many problems:
    etc ....
    last:
    BSP: MS9.H.32.1018
    MPEG:
    MCU: DNS810.141014
    BT: 20120512
    CAN:
    MAP:
    SOFTWARE:
    Yea mate sounds like it hasn't flashed properly. Do you have a record of what was previously installed? Did you read all the instructions and confirm what version you were supposed to flash?
  8. #708
    Sep 2014
    Laidley 4341 Qld
    Thank you Moda for the upgraded firmware. No prob with the update everything working as it should. Mine is DNS610 with the -A version Cheers
    Passat MY12.5 TDI.
  9. #709
    Oct 2014
    spain
    I canbus v1
    Can anyone confirm for me that the rear usb screens work?
    work from DVD ....
    from sd ...... NOT WORK
    from usb ..... NOT WORK
  10. #710
    Sep 2014
    Christchurch NZ (ex Brisbane)
    Will install on Sunday
