Hello.
Can someone with the last firmware these days?
Fixed bugs ARE YOU?
I've never used it but there is a composite (RCA) video output you could use for rear screens.
Hello.
Fixed bugs ARE YOU?
... what?
MY10 Golf Mk6 103TDI DSG Candy White | Revo Stage 1 ECU Tune | 18" Talladegas | GTI Front/Rear/Exhaust | R LED Taillights | GTI Steering Wheel | VW Discover Media | Focal IFVW Front Speakers | Mk7 Climatronic Panel |
Hi ...
fiona sent me this update .....
Has anyone proved?
https://www.dropbox.com/sh/iuhqkq4eb...ssHo-5_G9t4kBa
Not without knowing what build numbers/date/unit it's for...
The whole thing has been confused by the fact that there are now 2 types of DNS unit (old/new canbus decoder), and thus 2 software forks. Need to know what the build numbers are or have a link directly from Audiosources before i'm game to install it on my unit.
Pretty sure that was the problem with old mate a month or so ago who bricked his unit from a firmware flash, probably tried to install the other software fork.
ok ..
Where do I look?
is the model 3 months ago
dns-810
I'm really not sure what you're trying to do, to be honest, I think we're hitting a language barrier.
Chances are you probably have the new canbus decoder.
Without knowing what build numbers the firmware is, or having it come directly from Fiona, i'm not going to install it on my unit until someone else does *shrugs*
CURRENT FIRM....
BSP:MS9.F
MPEG:
MCU: DNS810.140114_01
BT: 20120512
MPUNS810.9005AS.20131220_16Bit
CAN: VW_HW_3013110791
MAP:
SOFTWARE:
reversing camera only works from dvd ....
from usb or sd does not work ....
Well that's a very strange collection of firmwares, pretty old. Looks like you would have the old CANBUS module too (same software version as me), maybe, not sure.
Either way, try that firmware version you got sent from Fiona.
Or you can try this: https://dl.dropboxusercontent.com/u/...8Aug14.V24.zip
This is the version I am running.
Edit: Make sure you follow the correct flash procedure, otherwise you will brick your unit.
