Page 69 of 106 FirstFirst ... 1959676869707179 ... LastLast
Results 681 to 690 of 1059
Thread: DNS series head unit (new generation dual core RNS-510 alternative)
  1. #681
    Dec 2012
    I've never used it but there is a composite (RCA) video output you could use for rear screens.
  2. #682
    Oct 2014
    spain
    Hello.
    Can someone with the last firmware these days?
    Fixed bugs ARE YOU?
  3. #683
    ... what?
    MY10 Golf Mk6 103TDI DSG Candy White | Revo Stage 1 ECU Tune | 18" Talladegas | GTI Front/Rear/Exhaust | R LED Taillights | GTI Steering Wheel | VW Discover Media | Focal IFVW Front Speakers | Mk7 Climatronic Panel |
  4. #684
    Sep 2014
    Christchurch NZ (ex Brisbane)
    Quote Originally Posted by dhparker View Post
    So I got my rear camera working (it was the wiring hookup) - and i've got the wiring going to the rear of the car, however, now I'm having problems getting the camera attached to the rear of the car. Its this style of camera - http://tinyurl.com/nfgfq5m not one that replaces the license plate late. The nut itself can't come off -
    Any advice on getting this on a VW rabbit/golf?
    Dave
    Drill a small hole between your release button and one of the licence plate lights, you may require a small mounting block to angle it correctly, remember to seal it with decent auto silicone.
  5. #685
    Oct 2014
    spain
    Hi ...
    fiona sent me this update .....
    Has anyone proved?
    https://www.dropbox.com/sh/iuhqkq4eb...ssHo-5_G9t4kBa
  6. #686
    Quote Originally Posted by lucas__ View Post
    Hi ...
    Has anyone proved?
    Not without knowing what build numbers/date/unit it's for...
    The whole thing has been confused by the fact that there are now 2 types of DNS unit (old/new canbus decoder), and thus 2 software forks. Need to know what the build numbers are or have a link directly from Audiosources before i'm game to install it on my unit.
    Pretty sure that was the problem with old mate a month or so ago who bricked his unit from a firmware flash, probably tried to install the other software fork.
  7. #687
    Oct 2014
    spain
    ok ..
    Where do I look?
    is the model 3 months ago
    dns-810
  8. #688
    ok ..
    Where do I look?
    dns-810
    I'm really not sure what you're trying to do, to be honest, I think we're hitting a language barrier.
    Chances are you probably have the new canbus decoder.
    Without knowing what build numbers the firmware is, or having it come directly from Fiona, i'm not going to install it on my unit until someone else does *shrugs*
  9. #689
    Oct 2014
    spain
    CURRENT FIRM....
    BSP:MS9.F
    MPEG:
    MCU: DNS810.140114_01
    BT: 20120512
    MPUNS810.9005AS.20131220_16Bit
    CAN: VW_HW_3013110791
    MAP:
    SOFTWARE:
    reversing camera only works from dvd ....
    from usb or sd does not work ....
  10. #690
    CURRENT FIRM....
    BSP:MS9.F
    MPEG:
    BT: 20120512
    MAP:
    SOFTWARE:
    Well that's a very strange collection of firmwares, pretty old. Looks like you would have the old CANBUS module too (same software version as me), maybe, not sure.
    Either way, try that firmware version you got sent from Fiona.
    Or you can try this: https://dl.dropboxusercontent.com/u/...8Aug14.V24.zip
    This is the version I am running.
    Edit: Make sure you follow the correct flash procedure, otherwise you will brick your unit.
