New DNS610
I took the plunge and bought a DNS610 direct from AS total package with reverse camera sd card and UPS total cost Au$535 .
The unit arrived on Tuesday 23rd very well packed 1 week after placing the order, let the fun begin.
The reverse camera was very easy to fit and works perfectly no mucking around spicing into other wires the power comes from the head unit.
GPS a bit of a prob here until I was told the GPS sd goes in on the right hand side not the left as clearly indicated in the accompanying manual !!! Have Primo installed and working but only as of last night so not really tested yet. I had to put the sd card in the socket multiple times before it would register so perhaps the socket is faulty.
Time set to GMT +8 and I cannot change it!! seems I need a program called total commander for CE to fix that . Any Ideas from members as I tried and failed on this.
The media outlet in the clove box does not work and the included accessory USB lead will only play from a drive when freshly inserted ,it will not find the drive if left plugged in after changing sources.
So far the the unit displays all the car info doors, A'con,etc and the wheel controls work. I still need to set up a phone so cannot comment on this yet .
Am i happy? so far its ok but I still have 40 days of PayPal indemnity left
I will post again as I progress. Cheers Garry
Passat 125 TDI B7.
