Page 62 of 106 FirstFirst ... 1252606162636472 ... LastLast
Results 611 to 620 of 1059
Thread: DNS series head unit (new generation dual core RNS-510 alternative)
  1. #611
    Dec 2012
    Quote Originally Posted by moda View Post
    .... haven't heard of a single brick.
    Well actually I've bricked one. The only way I know of is to cut the power during a BSP flash. Mine froze on the BSP flash screen after the stage where it erases the Nand ready for the flash, except it never got there. Just sat there for half an hour. Eventually had to turn it off and voila... Instant door stop...
  2. #612
    Dec 2012
    Malaysia
    Quote Originally Posted by Goobz View Post
    Oh crap.. Did u manage to fix it then?
  3. #613
    Dude, really? I had that exaccccttttt thing happen to me haha and mine was fine. Actually, I can't remember what part of it it stalled at, the part just before the creating MBR stage, it just stalled, and sat there for 20 mins not doing anything. I rebooted it, re initiated the flash and it worked fine.
    But since he only flashed the MCU, which is just the software, it should be fine?
    Correct me if i'm wrong, but its:
    BSP (Coloured writing on black screen) = Base Level WinCE Install
    MCU (prompt on insert card) = Unit Software Layer
    MPU (White screen) = Drivers
    Or something, right?
    Edit: The only other sure fire way to brick it is if you put the car into reverse while flashing. Not sure if that still applies for the DNS, but I remember reading in the ANS thread.
    Or if you try to flash DNS firmware onto a unit that actually isn't a DNS :p
    MY10 Golf Mk6 103TDI DSG Candy White | Revo Stage 1 ECU Tune | 18" Talladegas | GTI Front/Rear/Exhaust | R LED Taillights | GTI Steering Wheel | VW Discover Media | Focal IFVW Front Speakers | Mk7 Climatronic Panel |
  4. #614
    Dec 2012
    Quote Originally Posted by tunasandwich View Post
    Nope. Sandy replaced the whole unit for me.
    You have to see the coloured text screen come up first so if you didn't have that you should be OK. Do you have another SD card you can try? I grabbed a 4gb one to use for flashing. They cost nothing and you can keep it in the car in case you ever need to do a quick reflash while you're out and about.
  5. #615
    Yea, but I think his problem is that the unit won't even boot. Flashing the MCU, or MPU, or BSP, individually, should work fine without flashing all three at the same time.
    So either the flash went wrong somehow, or the units just being stupid, I dunno.
    Trying to force a BSP/MPU flash would probably be a good thing anyways.
  6. #616
    Dec 2012
    Malaysia
    Sorry, but what does BSP/MPU stands for actually?
    How do I force a flash? Just completely helpless here
    I actually used the micro sdcard that came with the GPS, i copied the GPS files out, and put the firmware files in....
  7. #617
    I explained what each of them are in my post above:
    (If that's correct, can't remember exactly).
    So what you did, if you just did the first flash on inserting the card into the booted unit, was just flash the MCU, which is the software layer (ie all the stuff you see ontop), you shouldn't have damaged anything critical (BSP/MPU).
    If you leave the card in while booting the unit, that will initiate the BSP/MPU flash.
  8. #618
    Dec 2012
    Malaysia
    i did leave the card and connect the unit... but once i connect it, the lights start flashing... holding down the power button doesn't do anything...
    appreciate your input... thanks...
  9. #619
    Dec 2012
    Did you format the card before copying everything onto it (making sure to do the UPD first) or just delete all the files then copy?
    Also make sure you format it to FAT32.
  10. #620
    Dec 2012
    Malaysia
    the first time i did it with just removing the files. then it screwed up, with the blinking lights.
    then i formatted it with FAT32 and tried it again, but it didn't work.
    the thing is the moment i plug it in, the unit starts to have it's lights blinking already...
