I'll give that a try, Thanks.
Is the flashing light at the CD Rom slot normal?
Did you follow the instructions in the spreadsheet?
You have to have a fresh, blank, newly formatted SD card. Put the UPD file on it first. Then all the other files (making sure you don't overwrite the UPD file). Boot the unit. Insert the SD card into the GPS slot, you'll be prompted to update and you select yes. Once it's done it should reboot itself. You may have to press (or press and hold) the power button for it to start. It should load into a black screen with coloured text, let it do its thing. It'll then show updating MPU. Let it do its thing. Once its done, it will prompt you to restart, pull the SD card and reboot it. Itll have a white screen with arrows, press each of the arrows with your finger nail or something pointy (screen calibration) and then it should load.
I (and others) have done hundreds of firmware updates with no issues whatsoever, they seem pretty difficult to brick, dunno what you've done otherwise?
Maybe try press and holding the power button, or if that fails, press and hold both power and tuner buttons, should force it to reset.
MY10 Golf Mk6 103TDI DSG Candy White | Revo Stage 1 ECU Tune | 18" Talladegas | GTI Front/Rear/Exhaust | R LED Taillights | GTI Steering Wheel | VW Discover Media | Focal IFVW Front Speakers | Mk7 Climatronic Panel |
It flashes constantly. Tried a fresh fat 32 formated Sdcard. Copied the Upd file, then the firmware, then the other files. Still doesn't work when i press and hold the power button. No black screen with colored text. Frustrating.
Pull the SD card out of the slot, unplug the unit for a few minutes and then plug it back in again. As I said, maybe try pressing and holding the power button, or both power and tuner dials or something.
You definitely have a DNS610, right? Should work with the firmware, and I haven't heard of anyone actually bricking their unit.
Edit: Maybe try getting in contact with audiosources, see if they can help you. At the very least they should be able to provide you with the recovery tools, unless you've seriously bricked your unit, which I don't think is even really possible. Fiona at marketing@audiosources.net is my contact.
If you've already flashed the MCU just try turning the car off, put the card in the GPS slot and then turn it on again. It should boot to the coloured screen then.
You could try pulling the radio fuse first too just to confirm it is reset properly.
i did take the sd card out, and unplug the whole unit for a few minutes. Tried pressing and holding the power button for a few minutes, yet still can't work. It should be a DNS610, got it from Audiosources directly.
I really hope i didn't brick it, i tried the factory reset as well, now the lights turn from red to green. I need to contact them now.
I'm really upset with this purchase..
I did, but i didn't pull the fuse, I disconnected the whole head unit though, that should be a proper reset, right?
Pulling the fuse and disconnecting the unit is the same (removes power from the unit, forces a reset). Pulling a fuse is just easier, usually, unless you already have the unit unscrewed :p
I'm sure you haven't bricked it, but I have no idea what you've actually done, as I said, heaps of us have done tonnes of reflashes on 610s and 810s, and haven't heard of a single brick.
FWIW Audiosources support can be a bit slow, they work on china time as well, so you won't get a response until tomorrow, probably.
Usually holding both the power and tuner dial down does a soft reboot.
But yes, next easiest thing is identifying which fuse is running the radio and pulling that one.
The I basically just followed the instructions on the excel to flash the firmware.. It went wrong just after i hit yes to update, and thr progress bar finishes and switches the unit off. Then the lights start blinking. And the unit doesn't boot up. I then unplug it out. I tried the factory reset button, and tried reformatting the sdcard and put in the files again. Still with the flashing lights when i plug it back in. Now its blinking in green light. I've unplugged the unit amd leave it for now. Damn..
I just plug it in again, and realise that it's not just the lights at the cd rom slot is blinking, all buttons and lights are blinking!!! Wth!!!
