Page 40 of 106 FirstFirst ... 3038394041425090 ... LastLast
Results 391 to 400 of 1059
Thread: DNS series head unit (new generation dual core RNS-510 alternative)
  1. #391
    Quote Originally Posted by fashionimage View Post
    @Moda Thanks, the salesman/tech at LSQ Star has been entertaining me and keeping in contact with me via Skype, he had me videotape and youtube the problems to him. I will keep you all posted as to what he says, but honestly Im about ready to ask him for a refund and if he says no I can file a paypal claim.(just want a radio that works), Has anyone tried Eonon?
    Also I Have some issues I don't recall reading about.
    1.When listening to any kind of media if the media volume is to loud you can't hear the GPS, the GPS isn't lowering the vol. when giving directions
    2.Bluetooth (audio only!! phone is fine) tin can distortion(sound almost like a blown speaker) and the Vol. on the Bluetooth is not very loud,you can't crack up the vol.
    let me know if this is happening to anyone else
    Thank you
    GPS sound thing might be fixed by playing with the GPS volume in the units menu (cant remember if its in the main menu or in the hidden menu), it might have been set to default too low.
    Otherwise, re the Eonons, they're cheap generic chinese units with a better skin/OS over the top. You have to know what you're getting (ie all the problems surrounding the chinese units, poor radio reception, build quality etc). IMO if you wanted a painless/easy/faultless install, probably best off with an OEM RNS510. Otherwise you'll probably always be fussing with something, or be annoyed by something (ie the chinese units software is hateful to use lol).
    MY10 Golf Mk6 103TDI DSG Candy White | Revo Stage 1 ECU Tune | 18" Talladegas | GTI Front/Rear/Exhaust | R LED Taillights | GTI Steering Wheel | VW Discover Media | Focal IFVW Front Speakers | Mk7 Climatronic Panel |
  2. #392
    Jun 2011
    I have new firmware which I am posting up in the OP.
    This firmware fixes an issue some people have been having with the unit getting stuck on the VW screen on boot.
    My impression from running this latest firmware is that it is pretty much rock solid - I have not had any boot issues, freezing issues or monsun.exe errors since installing it. So let me know if you have any problems with it. Please remember the new firmware update instructions and ALWAYS FLASH MCU FIRST.
    I'm working on Sygic implementation at the moment, I think this is the most sensible approach rather than hoping AS fixes the navigation / SD issue that only occurs with iGo. Other than this nav / SD issue, with the latest firmware there are only two issues that I can see:
    1. the screen brightness sometimes does not pickup that your headlights are on, and stays on the brightest level.
    2. the subwoofer adjustment in EQ appears to do nothing. I am told from a while ago that it does something else funky when you have sub-out connected. I told AS about this but they probably forgot - will chase it up again. This should be just a minor coding error.
    If you pick up any other errors please let me know.
  3. #393
    Quote Originally Posted by DkN View Post
    Groovy. Will give it a go and see how it goes
  4. #394
    Dec 2012
    I'll give it a run tomorrow. Thanks Sandy!
  5. #395
    Aug 2011
    Lake Macquarie
    any idea if it compatible with the 610?
    MKV Sportsline Soot Belcher
    MKV Jetta FSI DSG
  6. #396
    Aug 2011
    Lake Macquarie
    Quote Originally Posted by asa572 View Post
    Couldn't wait for an answer so I updated and it works with the 610 unlike the last update.
    Only issues I found so far is
    EQ:
    When you put it on loud it seems to do sweet f all other then putting **** loads of bass into it.
    Makes the door trims rattle and it's never done that before!
    Also when you adjust the treb, mid or bass it mutes the sound.
    When adjusting the balance/fade with cross hair it mutes the sound and is very laggy.
    Radio:
    I can't find where to turn on RDS for the radio.
    MKV Jetta FSI DSG
  7. #397
    Jul 2013
    Argentina
    EQ:
    Radio:
    What about the next/prev song while NAV in the foreground? Is it any better? I will try it today.
  8. #398
    Aug 2011
    Lake Macquarie
    Quote Originally Posted by matiasg85 View Post
    It's bad.
    Tried it last night and it is instantly laggy.
    Bad to the point where after less then a minute testing I powered down to shut the nav off.
    MKV Jetta FSI DSG
  9. #399
    Sd playback on nav is a lot better for me. ~5second lag between changing tracks (FLAC), and very little lag on volume changes.
    I have completely lost MFD functionality though. It just shows the default radio station, and won't change when I change stations or input source. I imagine this is because they've changed to the new CANBUS chip, software changes may not like the old chip?
  10. #400
    Jun 2011
    It's bad.
    As I said they have not found a solution to changing songs in SD with nav running in the foreground. They're working on it but I'm looking to switch to Sygic, which does not have this issue.
    The temporary workaround for now is to keep navigation running in the background (there will still be audio directions). Or, when the song is about to change, minimise navigation (by pressing the nav button) and bring the navigation back to the foreground after the song changes.
    Quote Originally Posted by moda View Post
    No, new CAN-Bus is still being tuned software-wise has not been implemented in the firmware. If you mean the audio menu in the MFD has disappeared, you just need to clear fault codes with VCDS and it should come back next time you start the car. The fault code does come back since it is not an OEM unit but for some reason the code clearing fixes the issue. I'm unsure why that happens occasionally yet, I think it used to happen due to the unit freezing on startup (which is now resolved), about when the car's CAN-Bus starts looking for MFD audio compatibility.
