I have new firmware which I am posting up in the OP.
This firmware fixes an issue some people have been having with the unit getting stuck on the VW screen on boot.
My impression from running this latest firmware is that it is pretty much rock solid - I have not had any boot issues, freezing issues or monsun.exe errors since installing it. So let me know if you have any problems with it. Please remember the new firmware update instructions and ALWAYS FLASH MCU FIRST.
I'm working on Sygic implementation at the moment, I think this is the most sensible approach rather than hoping AS fixes the navigation / SD issue that only occurs with iGo. Other than this nav / SD issue, with the latest firmware there are only two issues that I can see:
1. the screen brightness sometimes does not pickup that your headlights are on, and stays on the brightest level.
2. the subwoofer adjustment in EQ appears to do nothing. I am told from a while ago that it does something else funky when you have sub-out connected. I told AS about this but they probably forgot - will chase it up again. This should be just a minor coding error.
If you pick up any other errors please let me know.
