Page 36 of 106 FirstFirst ... 2634353637384686 ... LastLast
Results 351 to 360 of 1059
Thread: DNS series head unit (new generation dual core RNS-510 alternative)
  1. #351
    Jul 2013
    Argentina
    Quote Originally Posted by Goobz View Post
    I can. I'm amazed in the improvement in SD playback with this latest update! It loads in seconds, switches almost instantly and hasn't crashed once on me yet!
    Things are finally looking like they are going somewhere!
    Is yours a dns810 or dns610??
    Quote Originally Posted by chrislewis85 View Post
    Great stuff, although I'm not part of Sandy's groupbuy I'm glad others are having as positive an experience now as I seem to be having. This is really turning into a unit I enjoy showing off to fellow VW owners - it really does carry the OEM polished look/feel (and now snappier operation) of VW units 3x the price!
    One thing I have encountered - no matter how many times I've tried I cannot get the time/date to stay set correctly - it seems to keep jumping to China time (+7/8 hours) as if it is syncing via GPS/CANBUS but defaulting to the wrong timezone
    I suspect I may be the only UK owner on here currently but has anyone any input on this? Can't see anything in settings / hidden menu concerning time zone / syncing with GPS (time shows as correct in iGo Nav software)
    Do you have a dns810 or 610?
    About the time issue, i fixed it by going to the windows ce itself, and changing the time zone.
  2. #352
    Jun 2012
    Adelaide, South Australia
    I tried with no luck. Ended up just giving up. But it doesn't really bother me. Never turn my radio off anyways.
    On another note. Still not liking the way my Bluetooth is running. Just not quite right. Can't seem to keep sync with my phone. And has a few times lost connection mid call. Which it didn't start doing till about 2 months ago. Not sure what the deal is there.
    Sent from my Galaxy Nexus using Tapatalk
    Mine: -MK5 Golf 2.0TDI[Deiselgeek sigma 6 shifter + H&R 50mm lowering springs + GTI Tartan interior + Audi 18x8 A6 wheels(Dark Steel)]
    -MK1 Golf The re-spray/re-build
    In the family: -MK5 Jetta 2.0TDI, -9N3 Polo TDI, -6R Polo TDI, -Mitsubishi S^$&box van
    A pattern seems to be forming...
  3. #353
    Quote Originally Posted by matiasg85 View Post
    DNS810
    Interesting - how do you quit the UI to access CE desktop??
  4. #354
    Jul 2013
    Argentina
    DNS810
    I was just merely luck, i was trying to get the Garmin software to work, and it went off to the windows ce desktop.
  5. #355
    Ah I see thought you had a method!
    I wonder if putting a copy of ce 6.0's explorer.exe on the nav sd, and point gps path at it would work?? I will try this later
  6. #356
    Jul 2013
    Argentina
    No, it won't work, i will try to make a video showing you how to do it with the faulty garmin nav. It's pretty easy.
  7. #357
    Oct 2012
    Quote Originally Posted by DkN View Post
    I now have newer firmware that is supposed to be a lot more stable with regard to the monsun.exe error. However I have encountered an issue while flashing, and have now been told that there is a new firmware flashing procedure - the MCU MUST BE THE FIRST THING TO BE UPDATED. This is very important. I will update the spreadsheet in relation to the instructions as well. This doesn't mean your unit will have an issue if you don't flash the MCU first but you could get unlucky. So flash the MCU first - even if you have the most current version already.
    Hey Sandy, can you post exact procedure. I'm still on the safe firmware from Dec and have been hesitant to upgrade.
    I see the instruction on the excel doc but it doesn't sound like it is updating the mcu first?
    Sent from my LG-E975K using Tapatalk
  8. #358
    Dec 2012
    It's almost the same but now you put the card in with the unit powered up. Click yes on the pop up to upgrade the MCU first, then leave the card in when it reboots and it will do the BSP & MPU like normal. Then power off when instructed, remove the card, power on again and your done!
  9. #359
    Jul 2013
    Argentina
    Please, if anyone with a dns610 had luck upgrading to the latest firmware, post it here!!
  10. #360
    Jun 2012
    Quote Originally Posted by Fdandy View Post
    The procedure in the spreadsheet worked fine for me. Follow it exactly and it should work.
