Page 32 of 106 FirstFirst ... 2230313233344282 ... LastLast
Results 311 to 320 of 1059
Thread: DNS series head unit (new generation dual core RNS-510 alternative)
  1. #311
    Jul 2013
    Argentina
    Quote Originally Posted by asa572 View Post
    My 610 was pretty much ****ed with the April update hence why I am running a mix match setup now.
    Same here! Hehe. GPS was unusable with the april's software. THe "mix match setup" is working pretty fine, i still had some monsun.exe errors, and the next/prev/search on the SD/USB player is still laggy, and it's even worse when the navi is in the foreground.
  2. #312
    So, used SD today. 32gb Sandisk Class 10 Ultra card (45mb/s read, so no speed issues), variety of FLAC/MP3/M4A from ~1min to 3 hours.
    Issues I still have with the April firmware, with regards to SD playback:
    Music Pauses on Reverse
    ~5-30s lag between changing tracks (worse with Nav running, but there is still a significant lag without Nav, regardless of track type or length, 192kbps m4as still lagged)
    Lag with changing volume (worse with Nav running)
    Slow startup with SD playback (significantly better than it was, but still takes anywhere from 5-30s to load)
    No monsun issues though. Wasn't using directions though.
    So pretty much all the same issues. It is better than it has been, but still not good.
    This is ontop of all the other issues/missing features in the spreadsheet/I pointed out yesterday.
    MY10 Golf Mk6 103TDI DSG Candy White | Revo Stage 1 ECU Tune | 18" Talladegas | GTI Front/Rear/Exhaust | R LED Taillights | GTI Steering Wheel | VW Discover Media | Focal IFVW Front Speakers | Mk7 Climatronic Panel |
  3. #313
    Aug 2011
    Lake Macquarie
    I ran into a few issues while playing with my 610 tonight.
    Thought I would try the green skin, changed it in display and nothing, no lights at all.
    Change in the skin settings also to see if it would work and again nothing.
    Thank **** I don't own a skoda.
    Also when you hold the setup button on for a couple of seconds it brings up the touch screen set up.
    Thing was I couldn't get rid of it until I shut it down.
    Kept touching the cross hairs and it would just restart the process and it just went on and on and on.
    MKV Sportsline Soot Belcher
    MKV Jetta FSI DSG
  4. #314
    Jul 2013
    Argentina
    asa572, same issue with the green lights, they won't come up!
    By the other hand, i found another bug, when you are playing videos from the sd card, whenever you shut down the unit and start it again, the video will start from the beginning. One weird thing is that the video player is working faster than the music player, it will seek/next/prev almost instantly.
  5. #315
    Jul 2013
    Argentina
    Yesterday, after two hours nav + SD use, the physical buttons, stop responding, so i couldn't turn off the unit and i had to remove the fuse.
  6. #316
    Is it me, or are they just making these units worse and worse with each firmware release. I'm getting to the point that I don't even want this unit anylonger. Its not showing its 800 dollar value, more like the 150 dollar value that the customs paper showed.
    Sent from my S4 device via Tapatalk
  7. #317
    Dunno what you guys are doing but my 810 is working fine for me. Maybe its because i'm not using SD, though? *shrugs*
    @Sandy, any updates? I know its a Chinese holiday at the moment, but hopefully there is an update soon.
  8. #318
    Yeah I use SD all the time as I find the tuner is kinda crap, all I can hope for is a return unit that's better than this in both sd world GPS world and tuner world.
    My tuner is now randomly losing signal now too, joy
  9. #319
    Aug 2011
    Lake Macquarie
    Got the monsum error 5 times on a 15minute drive home tonight!
    This thing is awesome!
    MKV Jetta FSI DSG
  10. #320
    Yep, I see no improvements happening with that, if anything its getting worse. There should be a lemon law here.... I cant even resell the replacement unit with how badly things are with these units.
    I cringe thinking about the ans unit I have sitting for my dads car. Hope its not like this unit, I have my doubts tho.
