Thanks moda, i will try decemeber firmware tomorrow.
Seems like a really old firmware version?
MPU on that version is 16bit, I believe the SD/CPU issues got a bit worse when they went to 32bit, but the 16bit old version still had it. The older december firmwares also had the CANBUS/crashing issues, that's why I would be hesitant about using an older version.
BSP: MS9.F
MCU: DNS810.20131228
MPU: DNS810.20131228
That was the stable December version that I was using. It was 16bit, but still had the SD/CPU issues but didn't have any canbus/crashing issues.
Personally, the new April version works great for me, haven't had any issues (but then again, I don't use SD/USB).
I believe:
BSP = Firmware
MCU = Drivers
MPU = GUI/Software
So really what you guys are using is just an older version of the GUI/Software that is 16bit, and an older BSP. *shrugs*
MY10 Golf Mk6 103TDI DSG Candy White | Revo Stage 1 ECU Tune | 18" Talladegas | GTI Front/Rear/Exhaust | R LED Taillights | GTI Steering Wheel | VW Discover Media | Focal IFVW Front Speakers | Mk7 Climatronic Panel |
I think I might be doing something wrong, whenever I flash de older mpu I loose the reds and most of the sprites as in my previous pictures. Can you give me all the files you used to flash and your exact procedure?
Thanks in advance.
Matiasg85, what I did was start with the old firmware and then after the first part is loaded and you need to remove the SD card
the I loaded on the new firmware you were sent and used the MCU from that.
So put the december update on an sd and start putting it on the unit.
The when it asks you to reboot, shut it down and go and load the latest update
you were given from AS to the sd and finish the procedure with that.
MKV Sportsline Soot Belcher
MKV Jetta FSI DSG
