Page 30 of 106 FirstFirst ... 2028293031324080 ... LastLast
Results 291 to 300 of 1059
Thread: DNS series head unit (new generation dual core RNS-510 alternative)
  1. #291
    Seems like a really old firmware version?
    MPU on that version is 16bit, I believe the SD/CPU issues got a bit worse when they went to 32bit, but the 16bit old version still had it. The older december firmwares also had the CANBUS/crashing issues, that's why I would be hesitant about using an older version.
    BSP: MS9.F
    MCU: DNS810.20131228
    MPU: DNS810.20131228
    That was the stable December version that I was using. It was 16bit, but still had the SD/CPU issues but didn't have any canbus/crashing issues.
    Personally, the new April version works great for me, haven't had any issues (but then again, I don't use SD/USB).
    I believe:
    BSP = Firmware
    MCU = Drivers
    MPU = GUI/Software
    So really what you guys are using is just an older version of the GUI/Software that is 16bit, and an older BSP. *shrugs*
    MY10 Golf Mk6 103TDI DSG Candy White | Revo Stage 1 ECU Tune | 18" Talladegas | GTI Front/Rear/Exhaust | R LED Taillights | GTI Steering Wheel | VW Discover Media | Focal IFVW Front Speakers | Mk7 Climatronic Panel |
  2. #292
    Jul 2013
    Argentina
    Thanks moda, i will try decemeber firmware tomorrow.
  3. #293
    Jul 2013
    Argentina
    Quote Originally Posted by asa572 View Post
    How can we change the BSP file???
    Edit: just put the "Previous Stable Firmware" on and then updated to the MCU that was in the one AS sent you matiasg85.
    Seems to work fine.
    Attachment 9071
    Sorry, but what is the "Previous Stable Firmware"? Can i have it?
  4. #294
    Quote Originally Posted by matiasg85 View Post
    Previous stable firmware is the December 28 firmware I was talking about Link is in the spreadsheet. I'm not sure that it was made with the 610 in mind though? Either way I'd use the latest april firmware, or wait until the new version with the fixed SD/CPU issue?
  5. #295
    Aug 2011
    Lake Macquarie
    Quote Originally Posted by moda View Post
    Moda, it may not have been made with the 610 in mind but it works a hell of a lot better than the latest firmware when it's in my 610.
    MKV Sportsline Soot Belcher
    MKV Jetta FSI DSG
  6. #296
    Yep which is fairynuff. Whatever works best for ya'll
    Here's hoping that when they finally push out the fix for the SD/CPU issue it's all groovy If/When, being the biggest issue :p
  7. #297
    Jul 2013
    Argentina
    I think I might be doing something wrong, whenever I flash de older mpu I loose the reds and most of the sprites as in my previous pictures. Can you give me all the files you used to flash and your exact procedure?
    Thanks in advance.
  8. #298
    Jul 2013
    Argentina
    It looks like i wasn't updating the bsp (The black screen with "colorous letters", because i was using a 64GB card i was unable to format as fat. Now it is working.
    DNS series head unit (new generation dual core RNS-510 alternative)-img_20140426_155529-jpg
  9. #299
    Aug 2011
    Lake Macquarie
    Matiasg85, what I did was start with the old firmware and then after the first part is loaded and you need to remove the SD card
    the I loaded on the new firmware you were sent and used the MCU from that.
    So put the december update on an sd and start putting it on the unit.
    The when it asks you to reboot, shut it down and go and load the latest update
    you were given from AS to the sd and finish the procedure with that.
    MKV Jetta FSI DSG
  10. #300
    Jul 2013
    Argentina
    Did you notice any improvement? Is the MCU in the file i provided newer than the april's firmware? I will have to give it a try tomorrow. GPS is now usable, loudness is working again, and i like much better the "old"interface, with the "3d" bar in the USB/Sd player.
