Page 25 of 106 FirstFirst ... 1523242526273575 ... LastLast
Results 241 to 250 of 1059
Thread: DNS series head unit (new generation dual core RNS-510 alternative)
  1. #241
    Quote Originally Posted by LD_mart View Post
    Does the issue only occur when playing music through an SD card and running GPS at the same time?
    This would never effect me as i would never use an SD card to play my music
    Yep, it's a CPU bug when decoding music on the SD (and USB?) inputs. Should be getting a fix soon, but Sandy has indicated that it works fine if you use Sygic (it might be less CPU intensive?)
    Quote Originally Posted by chrislewis85 View Post
    Yes it does only affect SD playback (possibly USB also but not sure as I haven't thoroughly tested) Using CD/FM/Aux in seems fine.
    Is even worse if using a TTS voice in iGo (causes my audio to stutter), presumably because of the additional CPU resource required when generating voice instructions.
    If not using SD, iGo (Primo 2.4 on my unit) works perfectly and the unit as a whole is very snappy compared to other similar units I have used previously.
    Quote Originally Posted by powderskull View Post
    Followed this buy since last June - dropped off when all the problems cropped up. Now that all appears to be good hardware wise, I'd like to get in on the group buy before Sandy closes.
    In true Canadian fashion... "sorry" if this has been posted. I've scanned through 200+ thread pages just now (skipped some here an there), but I can't find the info.
    Questions:
    1) Does the BT screen display any song info? All I see from old demo vids is that it shows a blue screen with an icon on it. I understand the MFD may display music info in a future SW update (not sure if just SD music, or BT too...)
    2)
    "No battery drain issues" ... does that mean this unit doesn't require an updated CANBUS on early MK5's, like an RCD or RNS required to keep it from killing the battery?
    Sandy - I'll message you direct later tonight about group buy payment.
    1) As above, no info, just music controls. Not sure if it can be added in firmware though, dunno.
    2) No battery drain on my Mk6, but you should be aware that headunits like this use a lot of electricity, so if you run it on battery without the car on it'll drain the battery pretty quick.
    Quote Originally Posted by Justjuice View Post
    Hi guys.
    Does anyone with an amp and sub have any setting they're happy with? I just got my new unit and the bass sounds different to my stock RCD, which I recall was the case when I had my first DNS unit. I may be wrong as I dont have the best ear for this kind of thing but it almost sounds like the sub setting in the eq changes the amount of bass I get but it doesnt make it louder/quieter with the rest of the music if using the volume knob. Its almost like the sub setting is the only thing that makes it louder/quieter. But again I might be wrong as I may be hearing it incorrectly.
    Any ideas guys?
    My guess is that you haven't got the EQ settings quite right, might be worth playing around with the settings to see what happens.
    Quote Originally Posted by asa572 View Post
    Anyone else received there "production" unit yet?
    I received mine today and it seems to be more of a headache then the pre production units.
    Yep, swapped over the weekend, works fine.
    took me an hour to get it to download contacts from my phone.
    Ended up getting it done though.
    Tried two different SD cards in it and it keeps saying Bad SD.
    Good thing is I used the Sat Nav on the way to work this morning and
    there seems to be no conflict when playing music on USB.
    I was a little pissed when I received the replacement as I was sent a DNS610 which I originally ordered
    and not a 810 that I received for taking on the pre production unit.
    But after putting it in last night, IMO the 610 looks much better then the 810.
    I'll try the contacts/SD today, but everything works fine for me. Strange that you got sent the 610, I didn't realise they were in production yet.
    MY10 Golf Mk6 103TDI DSG Candy White | Revo Stage 1 ECU Tune | 18" Talladegas | GTI Front/Rear/Exhaust | R LED Taillights | GTI Steering Wheel | VW Discover Media | Focal IFVW Front Speakers | Mk7 Climatronic Panel |
  2. #242
    Jun 2011
    Sorry about shipping the 610, I was going off the invoices when placing an order for the replacement units and missed the fact that you opted for the 810 in the pre-production batch. Glad it worked out for you in the end though.
    I'm not sure why you're getting the bad SD error when your USB works fine. They are decoded by the same piece of hardware. I would suggest a firmware flash, but wait until I have the latest versions that are compatible with DNS-610 as well as 810.
    As for downloading contacts, it's hard to say how that happened but sometimes it could be from the phone. On Android you pair the device and when you try to open the phonebook another message on your phone should pop up saying that the unit is asking for permission to access the phonebook. Not exactly sure how it works with iPhones but BT connections can be finicky to setup at first and in those cases just forget / unpair the connection and start again.
    Quote Originally Posted by moda View Post
    The 610 was not available at the time of my ordering of pre-production units but it was actually the first unit to be available in the production units.
  3. #243
    Apr 2014
    Vancouver, Canada
    Thanks for the BT feedback!
    Damn, was hoping bt showed playback info.. . Blue screen is kinda useless. Lol
    Sent using Crapatalk
  4. #244
    Phone book download works fine for me, finished in about 30 seconds and pulled in everything.
  5. #245
    Aug 2011
    Lake Macquarie
    Quote Originally Posted by DkN View Post
    Got me beat why the SD doesn't work.
    It is the same card I used for music on the 810.
    I even removed all the music from it, formatted it and it still wouldn't work.
    GPS SD slot works fine, USB works good but the second SD slot keeps saying Bad Card.
    Streaming music with the Bluetooth is a little crackly also compared with the 810.
    MKV Sportsline Soot Belcher
    MKV Jetta FSI DSG
  6. #246
    Aug 2011
    Lake Macquarie
    Bought a new 32gig sd card and now it works.
    MKV Jetta FSI DSG
  7. #247
    Any updates on the firmware Sandy?
  8. #248
    Jun 2011
    There are multiple software releases coming through this week as AS applies several fixes to the software, I'm not sure as to what the fixes are yet but I will post something up this long weekend.
  9. #249
    Aug 2011
    Lake Macquarie
    Ok, thought everything was fine with my new DNS-610 but today it won't shut down.
    Was listening to music on SD when I stopped to talk to a mate, turned engine off but didn't pull the key so my missus could keep listening.
    Get back in the car and she says the volume won't work.
    I tried and it didn't.
    Pulled the key from the ignition and it wouldn't shut down.
    the only thing that would work were the touch screen functions like skip, pause, random and such.
    None of the function buttons would work.
    MKV Jetta FSI DSG
  10. #250
    Oct 2012
    Does it power down if you hold both round dials down? That normally resets it
    Sent from my LG-E975K using Tapatalk
