Page 13 of 106 FirstFirst ... 311121314152363 ... LastLast
Results 121 to 130 of 1059
Thread: DNS series head unit (new generation dual core RNS-510 alternative)
  1. #121
    Aug 2011
    Lake Macquarie
    Quote Originally Posted by asa572 View Post
    Sandy, can you confirm this is correct?
    Attachment 7063
    Quote Originally Posted by DkN View Post
    Can you please let me know what version of firmware you are running?
    Radio muting if you start the car after the unit boots is a known issue pending an MCU update to fix it.
    Firmware is the the same as the one I have asked about before. See above pic.
    As for the radio muting, I know it's a known issue but I have never had it mute after it is working then put it into reverse and then it's muted after putting it back into drive!
    As every other time it's happened it's been on startup.
    MKV Sportsline Soot Belcher
    MKV Jetta FSI DSG
  2. #122
    Dec 2012
    I will need to organise a replacement too once Sandy gets the final production units in. My SD is just not useable as the load times are like 30 - 40 secs every time you change a track and the BT audio quality the terrible like with the other guys units. Has anyone else had an issue with the BT during phone calls? Ive had quite a few people tell me thry can barely hear me unless I lean right into the radio which isn't that great while driving.
    Having said that they are my only issues with the unit and I've been quite pleased with it hardware wise.
    On the software front Sandy, can you please get something done about the screen brightness. I get no change whatsoever when headlights go on/off and the minimum setting with the reverse camera on is quite blinding at night making reversing up my long driveway quite difficult.
    Thanks mate.
  3. #123
    Milton, Ontario
    When will AS be back from holidays?
  4. #124
    Quote Originally Posted by swyner View Post
    Monday (10/02/2014) is typically when most chinese companies will be back at work (Pretty sure Sandy said AS will be back then too), but, I wouldn't expect a new firmware or anything for a bit after that anyways.
    Consider what it's like when we get back to work from the Christmas/New Years break every year, the last few weeks in december and the first few weeks in january are basically useless (they're the least productive months of the year). But that is the west, so China is probably different....
    MY10 Golf Mk6 103TDI DSG Candy White | Revo Stage 1 ECU Tune | 18" Talladegas | GTI Front/Rear/Exhaust | R LED Taillights | GTI Steering Wheel | VW Discover Media | Focal IFVW Front Speakers | Mk7 Climatronic Panel |
  5. #125
    Milton, Ontario
    Lmao. Very good point.
  6. #126
    Jun 2011
    Quote Originally Posted by kwalsh24 View Post
    Hmmm that does bring up another concern, what will these units do in the hot temperatures, we already know what they did in the cold temps, wonder if they will overheat and shut down or do anything funky
    Sent from my S4 device via Tapatalk
    They don't seem to have issues in hot temperatures but again this is just the first batch... the production units have no issues with temperature and does not have the white screen issue.
    monsun.exe error seems to be software related when I last spoke to the tech they are working on a fix.
    Quote Originally Posted by Goobz View Post
    Thanks mate.
    Is long load times while changing tracks only when you're using GPS?
    And are you saying your unit still blinds you if it's on the lowest brightness setting? That seems strange as I thought the lowest setting is not very bright at all
    I will be pushing AS to make sure their damned techs don't get any new year slack.
  7. #127
    Jun 2012
    Adelaide, South Australia
    I'd have to agree with goobz on the brightness setting. I drive at night with the unit on the lowest setting. And most of the time switch the screen off as its blinding. Especially if u driving on roads without many lights/traffic. Maybe there needs to be a super dim setting for those of us who want it dimmer for night time.
    Sent from my Galaxy Nexus using Tapatalk
    Mine: -MK5 Golf 2.0TDI[Deiselgeek sigma 6 shifter + H&R 50mm lowering springs + GTI Tartan interior + Audi 18x8 A6 wheels(Dark Steel)]
    -MK1 Golf The re-spray/re-build
    In the family: -MK5 Jetta 2.0TDI, -9N3 Polo TDI, -6R Polo TDI, -Mitsubishi S^$&box van
    A pattern seems to be forming...
  8. #128
    Funny, because I find even the brightest setting during the day is pretty weak, especially if you're wearing sunglasses (as you kinda have to do when youre driving in the middle of the day in rural aus), it can be pretty hard to see....
    No issues at night, lowest brightness is fine.
  9. #129
    Jun 2012
    Well daytime is bearable. Probably all the way up already. But I'm sure a lower setting is doable.
    What are your dash lights set on. I have mine turned all the way down, that could be why it blinds me.
  10. #130
    Oct 2012
    I find the Lowest setting a bit bright at night too. Also the brightness setting doesn't seem to save as every now and then I have to set it back to lowest setting from high.
    Sent from my LG-E975K using Tapatalk
