Page 12 of 106 FirstFirst ... 210111213142262 ... LastLast
Results 111 to 120 of 1059
Thread: DNS series head unit (new generation dual core RNS-510 alternative)
  1. #111
    Jun 2012
    Adelaide, South Australia
    Sandy when do you think the new units will be ready? My unit seems to be quite stable but I'm not using the current firmware.
    Do you think there is any chance the monsun.exe error is temperature related. As I had it pop up twice within a minute of jumping in the car on a 40+ degree day.
    Sent from my Galaxy Nexus using Tapatalk
    Mine: -MK5 Golf 2.0TDI[Deiselgeek sigma 6 shifter + H&R 50mm lowering springs + GTI Tartan interior + Audi 18x8 A6 wheels(Dark Steel)]
    -MK1 Golf The re-spray/re-build
    In the family: -MK5 Jetta 2.0TDI, -9N3 Polo TDI, -6R Polo TDI, -Mitsubishi S^$&box van
    A pattern seems to be forming...
  2. #112
    Hmmm that does bring up another concern, what will these units do in the hot temperatures, we already know what they did in the cold temps, wonder if they will overheat and shut down or do anything funky
    Sent from my S4 device via Tapatalk
  3. #113
    Jun 2012
    Well being 40 + for multiple days and this only happened once. Basically it got the monsun error as it loaded SD.
    Then I shut it down. And started it again.
    And about 30 SECS into the song it did it again.
    Hasn't happened since. Might be coincidental.
  4. #114
    It's been 35+ (and mostly 40+) degrees here since Christmas, and my car has been parked outside in the sun, and I haven't had any stability issues at all, so mine at least doesn't seem to be heat affected.
    I'll still need to organise a replacement when I get back (first week of March) to Brisbane, though, for the BT issue.
    Hey also, Sandy, how will the switch to 32bit effect the GPS software compatibility? As far as I'm aware most WinCE6 apps are 16bit? I imagine it will either run in emulation or the GPS module will run as 16bit while the head unit os will run in 32?
    Either way 32bit should help with the sd read issues, since it should allow it to address memory quicker etc.
  5. #115
    Jun 2012
    That's why I said it could be coincidental. But definitely keen to replace the unit. Hopefully the BT static will be fixed as that's really stopping me from using my phone for music.
  6. #116
    Wouldn't the bt static be more a hardware issue vs software ? Or are you still on a pre-release unit there polski?
  7. #117
    Jun 2012
    Still on pre-release. I don't think any of us Aussies have got a 'final' unit.
  8. #118
    Hmm wonder if anyone with a 'final' release in north America can answer that question for us bt streamers
  9. #119
    Quote Originally Posted by kwalsh24 View Post
    Yea, Sandy said the bt static is a hardware issue, replacement should be fixed.
    Id bloody hope so considering my $250 eonon unit in my prado has crystal clear bt streaming :p
  10. #120
    Wellllllll, yeah no comment haha
