Page 11 of 106 FirstFirst ... 9101112132161 ... LastLast
Results 101 to 110 of 1059
Thread: DNS series head unit (new generation dual core RNS-510 alternative)
  1. #101
    Milton, Ontario
    Wow never seen this forum so quiet!! Lol. Either that's a good thing or a really bad thing!!
    Sandy why did audiosources not get the firmware out before their year and a half holiday? Any update on the obdii module?
    Anyone else have the mirroring module? I would like to see if others have the same brutal low resolution image for their phone mirroring.
  2. #102
    Aug 2011
    Lake Macquarie
    Things that went wrong yesterday.
    First thing, started car with door open.
    Froze on door cue screen and muted sound.
    Reboot.
    Start car, muted radio.
    Reboot.
    Start car all is good, drive listening to SD and sound is lower than normal.
    Usually listen on 10, 11 or 12 know it needs to be around 15 and up.
    Then have that Monsum exe error come up.
    Seems the longer I use it the worse it gets.
    MKV Sportsline Soot Belcher
    MKV Jetta FSI DSG
  3. #103
    Well, least your radio still works! Could be worse, I still have zero buttons working, can't even power cycle the radio when the frozen white screen of death happens every time I start my car, also seems the more it gets used (when it does work) the worse it gets for system lag. The thing is like a ticking time bomb. I'm getting embarrassed to have the thing I my car knowing now much was spent on it.
    Best of all, its a in dash navigation unit, and I can't even use the navigation system in it as you can only access it by the non workin buttons.
    Sent from my SGH-I337M using Tapatalk
  4. #104
    Milton, Ontario
    Kwalsh24. Did you get a new production unit yet? Mine has been fairly stable so recommend that will help with a lot of your issues.
  5. #105
    Aug 2011
    Lake Macquarie
    Just had a new problem.
    Using SD and after the first song had played and went to the next song I ended up having no wheel controls, very laggy unit controls
    and could not do anything with the unit buttons but I could skip to the next song on the screen.
    Rebooted several times and it kept happening.
    Then it just stopped doing it and started working as it should.
    MKV Jetta FSI DSG
  6. #106
    Quote Originally Posted by swyner View Post
    No, haven't yet as sandy wanted to hold off in ordering so they can fix more software issues
    My issue is what if another firmware comes out and messes some units up, and not others like the past one just did, I don't want to be stranded a month with a dead unit, or have to pay (again) to have the system returned for what AS isn't capable of fixing
    Sent from my S4 device via Tapatalk
  7. #107
    Aug 2011
    Lake Macquarie
    New one this morning.
    Got in car an turned key to acc to let the unit boot up before starting the car.
    Radio comes on not muted.
    Put it into reverse and the sound mutes as normal.
    Reverse out the driveway put it into drive, radio stays muted
    and have to reboot to get sound back.
    MKV Jetta FSI DSG
  8. #108
    Jun 2011
    They did have one but said the recent switch to 32bit caused some new UI bugs and they want to fix those before giving me the firmware. This was a few days before they went on holidays of course... I expect to have something posted here within a few days of them returning.
    robk5787 is going to receive a replacement unit with mirroring module as soon as AS gets back. He should be able to confirm the quality - AS assures me that it's not normal to have bad quality image on the unit from the mirroring module.
    Quote Originally Posted by asa572 View Post
    Can you please let me know what version of firmware you are running?
    Radio muting if you start the car after the unit boots is a known issue pending an MCU update to fix it.
  9. #109
    Jun 2011
    Quote Originally Posted by kwalsh24 View Post
    Your unit has always seemed to be the worst and you had issues quite early on - I suspect other than the faulty resistor it also happens to be a faulty unit to begin with. As I mentioned in the other group buy thread, I would suggest that you just get a replacement now but it's your choice if you want to wait till I feel the unit is ready for release software-wise.
  10. #110
    Let's order up a replacement unit, as this thing is getting worse by the day.
    Only issue is, I have a real CD in the unit that isn't being ejected. So I guess I require a button fix to get the CD out so I can then return this unit.
