Hey guys,
After some correspondence with Sandy on Thursday he got back to me with an update for the firmware and also a can module upgrade. I've been running it since Friday and can confirm that silent boot is working properly and I haven't had a single flat battery or needed to double start the car since. I'm still going to give it a week to be sure the problem is completely fixed but I'm pretty optimistic so far.
Finally I'm also able to set the time too!!! There is an option to set it to sync with GPS as well!!!
Links are below for the new firmware. Remember it is
YOUR responsibility to ensure you are flashing the correct MCU depending on which unit you have. Not mine. If you are unsure, ask rather than bricking your unit!
Firmware:
https://dl.dropboxusercontent.com/u/...A_20150326.zip
This contains the MCU for the newer 'A' type units.
DO NOT FLASH as is if you have an old 'Non-A' unit – you must replace the A9_mcu_iap.hs file with this MCU file:
https://dl.dropboxusercontent.com/u/...AN%EF%BC%89.7z
You can then begin the flash. Remember, copy the UPD file to a blank SD first, then the rest of the files. Start with the MCU (turn on the unit and after it boots, insert the firmware SD into the GPS slot and a dialog box will pop up asking you to update MCU). Once done and the unit turns off, turn it on again and it will perform the rest of the flash. When the MPU update is finished you can turn off the unit and take the card out.
After this, delete all the files on your firmware SD (or use another one if you have a spare) and put this file on it:
https://dl.dropboxusercontent.com/u/96960779/VW_V02_32.ihs
This is the CAN-Bus update. The process is identical to MCU (insert SD card after the unit boots). Once that’s finished your unit will be completely up to date.
Here's mine after the update ('Non-A' Type):
Remember to confirm which MCU you need before doing this or you will brick your unit. Again if unsure post a pic of your system info page here and someone will be able to help you.
I am actuall really impressed with the service I received from him the other day. I emailed him Thursday morning, and by that evening he had contacted AS and sent me an update that has fixed the problems I was having. Can't ask for much better than that!
