Page 86 of 106 FirstFirst ... 3676848586878896 ... LastLast
Results 851 to 860 of 1059
Thread: DNS series head unit (new generation dual core RNS-510 alternative)
  1. #851
    Feb 2015
    Russia
    Quote Originally Posted by moda View Post
    If you want to risk it, try this, it is the latest that I have: https://www.dropbox.com/s/oey7ekhkfo...U_BSP.zip?dl=0
    It ONLY contains BSP/MPU, for units with ONLY the *NEW* CANBUS! I have deleted the included MCU since it would brick your unit. Try at your own risk!
    It contains versions:
    BSP: MS9.H.32.1119
    MPU: DNS810.02Feb15.32.VW.V45.C
    Thanks a lot! It is works on my DNS830 fine!
    I want to try edit language files. Is it real? It have bad russification.
    And I have no climate visualisation after MCU update. It shows only then i turn it off.
    And I have newer can software ver 2.34 but it is not turn off device automatically and now I use 2.27
    Attached Thumbnails Attached Thumbnails DNS series head unit (new generation dual core RNS-510 alternative)-20150413_001812-jpg
  2. #852
    Sep 2014
    Christchurch NZ (ex Brisbane)
    Quick update.
    Been running Sygic for some time now with very little issue - that being the zoom function
    Have noticed that at night the unit as 3 setting for brightness - bright, bright and screen off... Is there a setting hidden somewhere to adjust that?
    The unit is working fine otherwise
  3. #853
    Dec 2012
    Has anyone else had any battery drain issues? Since installing the new can chip I get a flat battery at least every other day. If not I have to start the car twice for the unit to power on. I think the silent boot feature is borked and not shutting off/booting up when it should. Its at the point now where I carry a battery pack around with me just in case.
  4. #854
    Oct 2012
    Quote Originally Posted by Goobz View Post
    Yeah. I reckon I'm having a battery drain issue. If I don't use my car for 3 or 4 days it drains the battery and I need to jump start. I've installed a new battery to help but I'm sure the unit is affecting it. Sometimes unit doesn't load past logo screen since last firmware and I soft boot it to get it going. Think we need new firmware.
  5. #855
    Mar 2015
    Greece
    I had the same problem with boot logo freezing with can VW_V02.33.
    I installed the older version VW_V02.27 and the problem was solved.
    Can i ask where did you people get Sygic from?I have searched the web and have found nothing to be working.
  6. #856
    Quote Originally Posted by Bassss View Post
    Editing system files is just going to be trouble mate, don't bother.
    Quote Originally Posted by subieboy View Post
    Quick update.
    I don't believe we ever had any better settings for brightness. It's never been an issue for me, though.
    Quote Originally Posted by Fdandy View Post
    No battery drain issues at all for me on my unit (Old CPU/New CAN) with:
    BSP: MS9.H.32.1119
    MCU: DNS810.1219
    CAN: VW_V02.28
    Even when I didn't drive the car for a week or so, started straight up, even on a cold morning (though I do have a brand new battery, with a much bigger capacity than stock).
    On the firmware side, no real show stopper bugs, just little things that would be nice to clean up, but otherwise running fine. MFD functionality still isn't great, but eh.
    Quote Originally Posted by craze View Post
    See my links here for a trial version Sygic 8.5 with 2013.09 maps: DNS series head unit (new generation dual core RNS-510 alternative)
    MY10 Golf Mk6 103TDI DSG Candy White | Revo Stage 1 ECU Tune | 18" Talladegas | GTI Front/Rear/Exhaust | R LED Taillights | GTI Steering Wheel | VW Discover Media | Focal IFVW Front Speakers | Mk7 Climatronic Panel |
  7. #857
    Dec 2014
    Athens, Greece
    Battery drain issues are related to old Can Gateway in your car.
    It is not a DNS problem as the same would happed even if you tried to fit a rather new verison of RNS510 or RCD510.
    Also, your CAN Gateway is not faulty, just incompatible with newer features/modules on the CAN bus.
    You probably have a prior 2007-2008 model.
    My 2010 Passat (build late on October 2009) has the CAN Gateway below and works fine.
    This is the CAN Gateway part of a VCDS scan of my car.
    Address 19: CAN Gateway Labels: 3C0-907-530-V3.clb
    Part No SW: 3C0 907 530 L HW: 3C0 907 951
    Component: J533__Gateway H13 0152
    Revision: H13 Serial number: 3300P09A14002F
    Coding: F9A07F46000202001002
    Shop #: WSC 05314 123 12345
    VCID: 2A5113E68547F64EEA7-807F
    No fault code found.
    A newer version 907 530 can be found on ebay for about 45€.
    You can find plenty of information about it but in case you plan to replace it yourself you will need to first get the current coding using VCDS in order to perform the same coding in the "new" CAN GW.
    I don't know the exact version needed for your cars but you have to start by knowing what exactly is currently installed.
  8. #858
    Mar 2015
    Greece
    I totally agree with kakourgos.
  9. #859
    Mar 2015
    Greece
    Hey moda thanks for the link but it does not contain the Greek map.
  10. #860
    I'm pretty sure we've talked about this before, thought we already discovered that those Sygic packs didn't have greek maps? Anyways. You have the program, now you can probably just go to Sygic and *buy* Greek maps... or whatever.
