Page 85 of 106 FirstFirst ... 3575838485868795 ... LastLast
Results 841 to 850 of 1059
Thread: DNS series head unit (new generation dual core RNS-510 alternative)
  1. #841
    Jun 2013
    I also emailed him last week to get my Sygic code. Unfortunately it did take him a few days to reply to my initial email.
    He probably only checks his emails once per week or something.
  2. #842
    Feb 2015
    Russia
    Hi all. I wrote before about I have bricked my DNS830 for Skoda Superb by updating wrong version of software. It was very hard to find Fiona from Audiosources but I did it! She said that I must replace MCU chip. She sold it for 5$ + 15$ for delivery. I gave the motherboard to a repair shop and the master soldered new chip for 6$.
    Now it works again! Now it has new version of MCU chip (DNS850.A.1106). Now I can switch on the SD card or usb device without rebooting
    Photo of moterboard from Fiona but I have another version. MCU chip is same and at same place
    Attached Thumbnails Attached Thumbnails DNS series head unit (new generation dual core RNS-510 alternative)-imgo-jpg   DNS series head unit (new generation dual core RNS-510 alternative)-20150404_135241-jpg
  3. #843
    Feb 2015
    Russia
    is there any new versions of software? ))) and can i update by this? what is the version of mcu there? will it work on my mcu? i want to reset all settings and to get clear system
    Attached Thumbnails Attached Thumbnails DNS series head unit (new generation dual core RNS-510 alternative)-20150403_184933-jpg
  4. #844
    Quote Originally Posted by Bassss View Post
    Mate, please don't PM me asking to answer your question, bit rude if we're honest.
    Anyways, if I were you, I wouldn't touch ANY firmware upgrades except those that you get directly from Audiosources. That way you will have the right firmware and you won't risk bricking your unit again.
    There are new a few different hardware iterations, it's pretty easy for someone who doesn't know what they're doing or who is unfamiliar with the history of the units to break their units now.
    Either way, your unit appears to be the new hardware and new canbus (but is a DNS850). The firmware you have linked is the same that you have installed (but for the DNS810). There are a few newer ones, but not much has really changed since then. I'm not going to upload it for you, sorry.
    MY10 Golf Mk6 103TDI DSG Candy White | Revo Stage 1 ECU Tune | 18" Talladegas | GTI Front/Rear/Exhaust | R LED Taillights | GTI Steering Wheel | VW Discover Media | Focal IFVW Front Speakers | Mk7 Climatronic Panel |
  5. #845
    Feb 2015
    Russia
    Audiosources says me it is newest software, but it is not! I want to have newest software and i vary want to do full reset. Now climatronic is not show on my DNS, only then i click OFF. And some another bugs
  6. #846
    Mar 2015
    Greece
    Quick question...
    Does anybody know where on the board is the ram located?
    Im thinking of upgrading to 1Gb ram which i believe will solve many problems.
    My main problem is while playing mp3 from usb and navigation running(Igo primo) when i change track it just freezes and if i press the navi button and navigation minimizes the track then changes.
    I believe this unit DNS610 has difficulty multitasking do to small Ram.
  7. #847
    I'll have a look at your versions again tomorrow and see what you can and can't flash.
    Quote Originally Posted by craze View Post
    Quick question...
    First of all, no. Lol no. Embedded Electronics don't work like that. You can't just solder some ram chips on and think it'll work, lol. Also, we've already well established that Primo doesn't work with the DNS. It's because of the country's, not ram.
    Use Sygic.
  8. #848
    If you want to risk it, try this, it is the latest that I have: https://www.dropbox.com/s/oey7ekhkfo...U_BSP.zip?dl=0
    It ONLY contains BSP/MPU, for units with ONLY the *NEW* CANBUS! I have deleted the included MCU since it would brick your unit. Try at your own risk!
    It contains versions:
    BSP: MS9.H.32.1119
    MPU: DNS810.02Feb15.32.VW.V45.C
    Quick question...
    Just to re-iterate, since I posted my last reply on my phone. You cannot do this. It will not work.
    The problem you have is because, as discussed many, many times before, iGo Primo is NOT compatible with these units. The root cause is that there is a bug with the CPU, because it is running WinCE6.0, which does not support multi-core CPUs fully. The ONLY way this bug will get fixed is by using a different OS (ie Android), which WILL NOT HAPPEN with the DNS series of headunits.
    The ONLY solution for us is to use Sygic Drive, which works flawlessly, and frankly, is a better navigation software than iGo anyways. The only reason iGo is more popular is because it is more mod friendly, much easier to find, and much easier to get free updated maps for.
    You absolutely CANNOT just try to solder on some more ram chips. You would probably destroy the unit in the process (since ramchips are precision BGA soldered on), and embedded electronics doesn't work like that anyways, even if you could solder on new/bigger chips, chances are it wouldn't be able to read the extra ram anyways. Not to mention the fact that WinCE only supports limited amounts of ram anyways. So yea, bad idea, don't bother, it won't fix anything, waste of time and money.
  9. #849
    Mar 2015
    Greece
    Thanks for the helpful info!
    I have tried various navigation software bu t they all have the same outcome...
    I have searched all over the web to find Sygic Drive but without any success!
    Is there any possibility i can find a working version of Sygic from here?I am only interested in the Greek map!
    I already spoke with Lisa from Audiosources and she told me that they dont have Sygic and that iGO works fine.
    Thanks again!
    Any help would be appreciated!
  10. #850
    Aug 2011
    Lake Macquarie
    Thanks again!
    Igo probably does work fine when they are running a simulated route while bench testing!
    In the real world when you use it in a car navigating it is no good.
    It's got me @#$%@# why they keep saying Igo works fine.
    MKV Sportsline Soot Belcher
    MKV Jetta FSI DSG
