Originally Posted by
asa572
New problem found.
driving with Sat Nav on, pressed the FM button to turn the volume up on the radio,
turned volume up and then I changed station to check the RDS was working.
After changing stations it locked up and was stuck on that station and was unable
to do anything.
Had to pull the fuse to turn it off.
This is an isolated incident, correct? This kind of lock-up really shouldn't be happening anymore without a hardware issue, but I will confirm.
On another note if you change the GPS volume setting in menu -> system so that it is set on 30 or something instead of "manual", you don't need to exit GPS in order to change the volume of the background application whether it is radio or SD or something else.
robk5787
Anyone else notice that the radio will mute itself when you sound the horn. Got cut off yesterday and gave a quick honk of the horn, and the radio muted. Interesting! I drive a MK6 with Kessy, if it matters.
Speaking of that, I have a new test MCU that is supposed to fix all radio muting issues. Apparently some people still experience radio muting when starting the car though this no longer happens in my car - that is what this MCU is meant to fix. Would anyone with radio muting issues please test and report back (since mine is already fixed before this MCU for some reason). Link is in first post, under firmware section.
swyner
Sandy, have you been able to test the HD Link unit with an Android phone? I haven't had time to take a screen shot for you but wondering if you (or anyone else) has used this yet. My first impressions are that the interface is NOT 480p which is what the DNS screen resolution should accept. The whites are more of a gray color and the colors are washed out. So far this "mirroring" unit is not impressive but would like to see if anyone else has had a chance to use it.
Also, have you inquired about the timeline for the OBDII unit? 3G modem?
I received an response saying that the low quality you are experiencing is not normal, but I don't have the module with me to test for myself. I'm waiting for confirmation from a US customer who may be receiving a replacement unit with an added mirroring module much like yourself very soon, so we can get a comparison.
I still need to follow up on OBD2 and the 3G availability though software-wise 3G has already been enabled.
