Originally Posted by
DkN
As I said they have not found a solution to changing songs in SD with nav running in the foreground. They're working on it but I'm looking to switch to Sygic, which does not have this issue.
The temporary workaround for now is to keep navigation running in the background (there will still be audio directions). Or, when the song is about to change, minimise navigation (by pressing the nav button) and bring the navigation back to the foreground after the song changes.
No, new CAN-Bus is still being tuned software-wise has not been implemented in the firmware. If you mean the audio menu in the MFD has disappeared, you just need to clear fault codes with VCDS and it should come back next time you start the car. The fault code does come back since it is not an OEM unit but for some reason the code clearing fixes the issue. I'm unsure why that happens occasionally yet, I think it used to happen due to the unit freezing on startup (which is now resolved), about when the car's CAN-Bus starts looking for MFD audio compatibility.
