Page 37 of 106 FirstFirst ... 2735363738394787 ... LastLast
Results 361 to 370 of 1059
Thread: DNS series head unit (new generation dual core RNS-510 alternative)
  1. #361
    Aug 2011
    Lake Macquarie
    I think you and I are the only ones with the 610's
    MKV Sportsline Soot Belcher
    MKV Jetta FSI DSG
  2. #362
    Quote Originally Posted by matiasg85 View Post
    No, it won't work, i will try to make a video showing you how to do it with the faulty garmin nav. It's pretty easy.
    Thanks but got access to control panel and fixed it - pointed nav path at a copy of total commander, ran explorer.exe from /Windows folder and got into control panel
    It's all chinese symbols but i recognised appropriate options and set it to GMT with DST, time and date now syncs correctly
    Thanks for the tip!
  3. #363
    Oct 2012
    How did you get total commander loaded?
    Sent from my LG-E975K using Tapatalk
  4. #364
    Quote Originally Posted by Fdandy View Post
    Downloaded a package called 'Vista unlock 800x480' which is mentioned on gpsunderground as a customizer/launcher for chinese GPS units
    Unzipped it onto Nav SD, then pointed GPS path at the .exe file in programs\Total commander (not sure what else this Vista unlock 800x480 does but it includes total commander)
  5. #365
    Oct 2012
    Thanks. Got it sorted out too.
  6. #366
    Aug 2011
    Lake Macquarie
    Please, if anyone with a dns610 had luck upgrading to the latest firmware, post it here!!
    did you end up trying the update??
    I have done it 3 times now with the same result each time.
    MKV Jetta FSI DSG
  7. #367
    Oct 2012
    Ok, on the latest firmware. Nav seems a little less responsive and sd playing still slow however I havnt had any monsun errors. Think the last safe firmware was better IMO.
  8. #368
    Jul 2013
    Argentina
    Quote Originally Posted by asa572 View Post
    No, i haven't had time, and i don't think i will try it. I was speaking to an AS representative, and they told me they are still working on the firmware for the DNS610, i might wait for theirs. I will post it here once i have it.
  9. #369
    Jun 2012
    Adelaide, South Australia
    Did you use the new procedure??
    Mine is noticeably better. Nav is ALOT faster to load and to go through the menu. And the SD loads in a few seconds Compared to 10-15 previously.
    Sent from my Galaxy Nexus using Tapatalk
    Mine: -MK5 Golf 2.0TDI[Deiselgeek sigma 6 shifter + H&R 50mm lowering springs + GTI Tartan interior + Audi 18x8 A6 wheels(Dark Steel)]
    -MK1 Golf The re-spray/re-build
    In the family: -MK5 Jetta 2.0TDI, -9N3 Polo TDI, -6R Polo TDI, -Mitsubishi S^$&box van
    A pattern seems to be forming...
  10. #370
    Dec 2012
    Quote Originally Posted by polski_ogurek View Post
    I've had the same experience however I still can't run the 2 together with out the unit locking up and crashing after a short while. Not a monsun error. Just freezes and needs a reboot.
