Page 31 of 106 FirstFirst ... 2129303132334181 ... LastLast
Results 301 to 310 of 1059
Thread: DNS series head unit (new generation dual core RNS-510 alternative)
  1. #301
    Aug 2011
    Lake Macquarie
    Quote Originally Posted by matiasg85 View Post
    Did you notice any improvement? Yeah, It didn't **** itself all day yesterday!
    Is the MCU in the file i provided newer than the april's firmware? I don't know
    I will have to give it a try tomorrow. GPS is now usable, loudness is working again, and i like much better the "old"interface, with the "3d" bar in the USB/Sd player.
    I did notice that the going to the next song on USB was a lot quicker and it just felt better to use.
    I much prefer the old interface also.
    MKV Sportsline Soot Belcher
    MKV Jetta FSI DSG
  2. #302
    Jul 2013
    Argentina
    Quote Originally Posted by asa572 View Post
    This! I will definitely give it a try tomorrow.
    Thanks.
  3. #303
    Aug 2011
    Lake Macquarie
    with the latest update Sandy supplied you would hut the next button and a tab world pop ip on the screen saying next and then it would go to the song.
    It doesn't do that with the way I did it.
    MKV Jetta FSI DSG
  4. #304
    Jul 2013
    Argentina
    Just flashed the AS MCU, an as you said, going tto the next song on USB when using igo is working a LOT better.
  5. #305
    Jun 2011
    I've discussed with AS and the old interface for SD should be returning in the next update.
    To be clear what issues were you having with the latest update? My experience is that with the older updates, music still stutters while GPS is running, and the monsun.exe error came up a lot more often. For me, since flashing to the latest April firmware, music never stutters, and I've yet to run into a monsun.exe error. I've told them about the EQ issues, other than loudness not working it appears the "sub" adjustment does nothing. The issues seem connected and look to be just a small, easily fixed error.
    It may be that it's just the 16bit MPU that make things a bit snappier. If that is the case I may ask AS to do a parellel release of 16bit MPU every time, if that's possible. Personally I didn't find too big of an improvement jumping from 16bit to 32bit.
    I am to have test firmware for the song changing issue when in GPS this weekend.
    I also convinced AS to stop any development on new features for now and focus solely on bugs, which will hopefully speed things up.
  6. #306
    So far the issues I've had with the update, which weren't there before the update :
    GPS fades both front speakers, and sometimes doesn't return them back to full volume after giving voice guidance.
    Sub cuts in and out, also seems that the bass issue is back where its overpowering, my sub adjustment works ? Mind you I hace to have base at 0 to 2 and sub. At 0 to -2 otherwise it's crazy bass
    Issues that still carry on from previous firmwares
    My system still has lag when using GPS and SD playback, must be my unit. Delays on advance track & entering menus / selecting different inputs & volume adjustment delay still.
    Sent from my S4 device via Tapatalk
  7. #307
    Quote Originally Posted by DkN View Post
    Haven't had the chance to look at SD/Nav playback with the April firmware, but various iPod related bugs, as well as the little spelling mistakes and things like that, as per the spreadsheet, still exist. Some of them are very minor, but make a difference in terms of the shine of the OS. Plus little usability tweaks (granular control of backlight, ability to choose what sources the SD button flicks through, display of track titles over BT etc).
    I'll have a better play tomorrow with Nav/SD etc and see what else I can come up with.
    MY10 Golf Mk6 103TDI DSG Candy White | Revo Stage 1 ECU Tune | 18" Talladegas | GTI Front/Rear/Exhaust | R LED Taillights | GTI Steering Wheel | VW Discover Media | Focal IFVW Front Speakers | Mk7 Climatronic Panel |
  8. #308
    Jun 2012
    Adelaide, South Australia
    I'm still getting the monsun.exe error. Had it about 5 times so far since the update. What is the cause of this error?? Why is it so common and persistent??
    Sent from my Galaxy Nexus using Tapatalk
    Mine: -MK5 Golf 2.0TDI[Deiselgeek sigma 6 shifter + H&R 50mm lowering springs + GTI Tartan interior + Audi 18x8 A6 wheels(Dark Steel)]
    -MK1 Golf The re-spray/re-build
    In the family: -MK5 Jetta 2.0TDI, -9N3 Polo TDI, -6R Polo TDI, -Mitsubishi S^$&box van
    A pattern seems to be forming...
  9. #309
    I've had it 3 or 4 times now, on random tracks. Just with SD playback nothing else, its happened in the middle of a song, or advancing to the next. Weird how we the users get the error to happen but the techs can't.
  10. #310
    Aug 2011
    Lake Macquarie
    My 610 was pretty much ****ed with the April update hence why I am running a mix match setup now.
    MKV Jetta FSI DSG
