Page 27 of 106 FirstFirst ... 1725262728293777 ... LastLast
Results 261 to 270 of 1059
Thread: DNS series head unit (new generation dual core RNS-510 alternative)
  1. #261
    Updated this morning. SD playback/loading seems significantly faster (the SD Loading screen only shows up for ~3-5 seconds now, it used to take over 30 seconds, even with the march firmware). It also now properly remembers the song position, even in long tracks (ie 1-2 hour dj sets), which is nice, and even on FLAC. Haven't tried it with the Nav yet, though, so can't comment there.
    SD tracks still pause when you go into reverse, but I imagine this may be the SD issue. It's really annoying though.
    Other than that, the tweaks have been mostly aesthetic. A few new images here and there (aux screen/SD loading), and they've changed the layout of the setting screen. It may be closer to the OEM units style, but frankly it's a bit more inefficient than the previous 2 column setup. It takes 2-3 touches to get into the right menu now, that used to take 1-2 (because there are now menus nested within other menus, ie BT/Radio settings are under 'Functions', and you have to scroll down from the initial settings screen. When you back out of a menu it also returns you back to the top instead of back to the position you were in the initial screen (ie if you scroll down one page, then go into a menu, then go back out, it takes you back to the top instead of back to the 2nd page). Not a big deal, but just slightly annoying. @Sandy, can you pass on this feedback?
    The red highlights asa is talking about is the track progress bar, it used to be a slightly darker red and have some grey space in it, now its solid red. I kinda preferred the old look, but whatever, its not a big deal.
    Still some small spelling mistakes ('modle' and 'hightest'), but I think most of the rest of the bugs have really been touched on with the production hardware and latest firmware.
    Only thing left is some missing features (obv the biggest being the music library/3 line MFD, but also some usability tweaks like steering wheel button behaviour/aux cycle selection/bt a2dp info/brightness behaviour etc).
    Quote Originally Posted by asa572 View Post
    Just installed the latest firmware and all I can say is WTF were they thinking?
    They must have dropped some serious acid while developing that sh^t.
    That new setup menu is totally f@#ked up.
    And the RED HIGHLIGHTS, ahhhhhhh it hurts my eyes! < seriously it does
    Don't worry about masturbating making you go blind.
    Driving your Golf with an AS head unit will make you go blind faster.
    And yes, I had the brightness on the lowest setting.
    It's not that bad, to be honest.
    Quote Originally Posted by matiasg85 View Post
    Can you guys show some pictures to decide wether to go or not to go with this new firmware?
    Some images here: Audiosources DNS810 April Firmware - Imgur
    Not the biggest gallery, but gives you an idea of some of the things that have changed. It's really not that big of a change.
    MY10 Golf Mk6 103TDI DSG Candy White | Revo Stage 1 ECU Tune | 18" Talladegas | GTI Front/Rear/Exhaust | R LED Taillights | GTI Steering Wheel | VW Discover Media | Focal IFVW Front Speakers | Mk7 Climatronic Panel |
  2. #262
    Jul 2013
    Argentina
    I have just flashed the lastest firmware, and the skip/fwd bug in usb/sd is still happening, and the Laggy gps is even worse than in the previous fw. I hope they fix this soon.
    Edit: About the spelling mistakes, within the car info, thw word volatage instead of voltage.
    Checking at your pictures, it seems that my MCU did not update properly, since it is showing DNS810.140114_01 under system info.
    Is it safe to go back to the previous MPU??
  3. #263
    Aug 2011
    Lake Macquarie
    Quote Originally Posted by moda View Post
    Wait till you try it at night!
    MKV Sportsline Soot Belcher
    MKV Jetta FSI DSG
  4. #264
    I'll have to give the SD/Nav a go, but seemed fine to me *shrugs*
    I flashed the april firmware plus the february DNS810 MCU. I don't know if that makes a difference, but I figured I may as well try and have the latest on there. AFAIK they included the jan MCU with the april firmware because its compatible with the 610.
    You should be fine to go back and forth between any of the different firmware parts, but ymmv.
    True, but i've never had any issues with the brightness at night like others have, so it probably won't make any difference to me.
    It's still one of the things I noted that was missing, and that was the ability to have granular control over backlight settings.
  5. #265
    Jan 2013
    Flashed the latest firmware earlier today and my screen went a bit haywire with fuzzy text - did any of you experience this? Once the initial part was complete I turned off the unit and all went back to normal before I proceeded with the second stage. Looks like the unit successfully updated however I have encountered several monsun errors since flashing...
    Sent from my GT-I9305 using Tapatalk
  6. #266
    Aug 2011
    Lake Macquarie
    Quote Originally Posted by cpkk View Post
    I experienced this.
    Mine went a pink colour and the text saying do not shut down went from the right side on the screen to the left.
    And when I restarted it to finish the update the radio screen was only just recognisable.
    But it ended up coming good.
    MKV Jetta FSI DSG
  7. #267
    Jun 2012
    Adelaide, South Australia
    I personally liked the way the previous version looked, there's just too much red now, black and white always works, will see what its like at night, but not the best looking now, the brightness is still a PITA, [E.G. change song, turn screen off, go to change song again, turn on screen(get used to blindness) change song and turn screen off, its ok when im in the city, but I drive through some dark areas on the way home, and I would go as far as saying its dangerous how bright it is.]
    on a side note, Sandy, when will the next batch of production units be coming, keen to swap mine as the Bluetooth playback with feedback is really annoying.
    I experienced this.
    I too had this, then it came up ok, no issues since. This did happen when I flashed the Feb update too, but wouldn't go away at that stage. So I went back to the trusty December firmware.
    Mine: -MK5 Golf 2.0TDI[Deiselgeek sigma 6 shifter + H&R 50mm lowering springs + GTI Tartan interior + Audi 18x8 A6 wheels(Dark Steel)]
    -MK1 Golf The re-spray/re-build
    In the family: -MK5 Jetta 2.0TDI, -9N3 Polo TDI, -6R Polo TDI, -Mitsubishi S^$&box van
    A pattern seems to be forming...
  8. #268
    Yep, happened to me some times when flashing. Reboot and its fine. It happened more with my old unit, or when flashing between 16 and 32bit versions (ie going from the december firmware to a newer one). If you're getting monsun errors, i'd say reflash it again, just to make sure.
  9. #269
    Aug 2011
    Lake Macquarie
    Ok, the red problem I had last night, I forgot that when you turn the lights on the screen reverts to the brightest setting automatically (which is a pain).
    Realised this tonight and when put back to the lowest setting the red isn't as bright.
    Other problems I found on the way home.
    With Nav running (not navigating just running) SD will play a song till the end and not proceed to the next song unless I hit the NAV button
    to bring up the SD Screen or hit the media button to bring up the SD screen. As soon as I do this the next song will start.
    Driving along listening to SD and it just changed to RADIO.
    The LOUD ON/OFF option in the Equalizer does not work.
    None of the above problems happened with the firmware that my unit was delivered with.
    MKV Jetta FSI DSG
  10. #270
    Haha. Yea like I said, having granular control of the brightness settings is probably the most needed feature thats missing at the moment.
    Yea, that's still the SD/CPU decoding issue. Hopefully they can get it fixed as per sandys post by the end of the month (yea, I wish).
    Loud on/off on the EQ works for me, gave me a hell of a fright when I was playing with the EQ earlier today lol.
