I can't give an ETA at this stage because AS has not given me an ETA on fixing the nav / SD issue. Likely they will just tell me when it is fixed, I will confirm with the software myself, and I will then wrap up the group buy. If this doesn't occur soon I am considering using Sygic as the navigation software instead, because the nav / SD issue does not exist with Sygic. However the preference is to stick with iGo.
Does the issue only occur when playing music through an SD card and running GPS at the same time?
This would never effect me as i would never use an SD card to play my music
Followed this buy since last June - dropped off when all the problems cropped up. Now that all appears to be good hardware wise, I'd like to get in on the group buy before Sandy closes.
In true Canadian fashion... "sorry" if this has been posted. I've scanned through 200+ thread pages just now (skipped some here an there), but I can't find the info.
Questions:
1) Does the BT screen display any song info? All I see from old demo vids is that it shows a blue screen with an icon on it. I understand the MFD may display music info in a future SW update (not sure if just SD music, or BT too...)
2) "No battery drain issues" ... does that mean this unit doesn't require an updated CANBUS on early MK5's, like an RCD or RNS required to keep it from killing the battery?
Sandy - I'll message you direct later tonight about group buy payment.
Hi guys.
Does anyone with an amp and sub have any setting they're happy with? I just got my new unit and the bass sounds different to my stock RCD, which I recall was the case when I had my first DNS unit. I may be wrong as I dont have the best ear for this kind of thing but it almost sounds like the sub setting in the eq changes the amount of bass I get but it doesnt make it louder/quieter with the rest of the music if using the volume knob. Its almost like the sub setting is the only thing that makes it louder/quieter. But again I might be wrong as I may be hearing it incorrectly.
Any ideas guys?
Anyone else received there "production" unit yet?
I received mine today and it seems to be more of a headache then the pre production units.
MKV Sportsline Soot Belcher
MKV Jetta FSI DSG
Yes it does only affect SD playback (possibly USB also but not sure as I haven't thoroughly tested) Using CD/FM/Aux in seems fine.
Is even worse if using a TTS voice in iGo (causes my audio to stutter), presumably because of the additional CPU resource required when generating voice instructions.
If not using SD, iGo (Primo 2.4 on my unit) works perfectly and the unit as a whole is very snappy compared to other similar units I have used previously.
took me an hour to get it to download contacts from my phone.
Ended up getting it done though.
Tried two different SD cards in it and it keeps saying Bad SD.
Good thing is I used the Sat Nav on the way to work this morning and
there seems to be no conflict when playing music on USB.
I was a little pissed when I received the replacement as I was sent a DNS610 which I originally ordered
and not a 810 that I received for taking on the pre production unit.
But after putting it in last night, IMO the 610 looks much better then the 810.
MKV Jetta FSI DSG
