Page 2 of 2 FirstFirst 12
Results 11 to 14 of 14
Thread: Discover Pro (MIB2.5) Stuck on boot splash screen
    I've been away on holiday.
    I'll send you some docs via email.
    Dec 2021
    Launceston, TAS
    Just to provide a resolution in this thread...
    Huge thankyou to kamold and his efforts and numerous answers via email in trying to get the issue resolved.
    Eventually I got it fixed today with the help of a user who contacted me via my post on jilleb's (MIB2 Toolbox's dev) github. We were about to re set the skin using long coding through the serial terminal interface into emergency boot mood.
    Apr 2020
    Poland - Europe
    Quote Originally Posted by leifalbor View Post
    Can you provide me with information you got? I am in the same situation. I changed skin and I can see starting logo only.
    @wachu153: Hmm....... if your problem has resulted from coding changes and you have used a diagnostic device like OBD11, or VCDS - the software will contain a record of the details of the tweak.
    So, a way of often (and easily) fixing this problem is to simply revert the coding change the caused the fault back-to the original setting!
    As I say, you already have the necessary data for this fix if you have used a good diagnostic device - why not try?
