Originally Posted by
kamold
VPS should be disabled. That's only for OEM highline control module.
kamold : Yes, I agree.
However, and notwithstanding OP's belief that this is a low-line camera, the device DOES has CAN High/Low wires - which as you will know, is very much a characteristic of a high-line device on the OEM version camera.
Why would a low-line camera need CAN wires? Low-line cameras simply need power and a trigger wire from the reverse-light to initiate the Video signal! This OEM camera has both the low-line trigger wire (item "3" in OP's picture) AND CAN wires - very odd!!!
