Page 51 of 57 FirstFirst ... 414950515253 ... LastLast
Results 501 to 510 of 567
Thread: Discover Media retrofit
  1. #501
    Jan 2024
    canada
    Confirm that the following adaptation channel is set to 'FBAS':
    IDE03471-ENG126143-Vehicle configuration-RVC_video_input
    Also confirm with a multimeter that the camera is getting 12v.
    it must be getting 12V as i see/hear it come ON and flip open when i put the car in reverse
    also should i put these TWO adaptations back to NOT ACTIVE??? because DON asked me to set them to this
    1. Car Function List BAP Gen2 → VPS_0x0B > active
    2. Car Function List BAP Gen2 → VPS_0x0B_msg_bus > terminal 15, or comfort data bus, or infotainment data bus
    also what i have noticed that when i connect the can lines (+ and -), this particular camera also needs/requires 12V switched voltage, and if i put that fused line in a spot ( in this case a spot where its taken by another fuse/circuit as my R don't have any free spots it gives me an error when i do a scan....for that particular circuit, in this case something to do with headlights
    but i dont' get those errors if i dont' connect the switched 12V, it's weird
  2. #502
    VPS should be disabled. That's only for OEM highline control module. Was worth a try.
    You don't have a PDC module so you need to disable PDC adaptations:
    ENG122227-ENG117496-Car_Function_Adaptations_Gen2-menu_display_pdc
    ENG122227-ENG117498-Car_Function_Adaptations_Gen2-menu_display_pdc_over_threshold_high
    ENG122229-ENG117710-Car_Function_List_BAP_Gen2-parking_assist_0x0A
  3. #503
    Jan 2024
    canada
    VPS??? what's that?? all this is gibberish to me
    so all these
    need to be disabled??
    what about the other 2 adaptations i mentioned?? should i return them to NOT active as they were before?
    i'm not too fluent when it comes to using vag com and changing stuff...so i need more step by step info....LOL
  4. #504
    Jan 2024
    canada
    theses are all the wires that this camera from RCD330.com requires to be hooked up
    Discover Media retrofit-rcd330-wires-hook-up-jpg
    Discover Media retrofit-can-wires-jpg
  5. #505
    Mornington Peninsula, VIC
    Is that camera plug going directly to your quadlock that goes into the MIB not the adaptor right?
    I like to test RVCs with an old portable screen that has video in (the yellow rca) to see if it's outputting.
    MY12 Passat FSI Highline | 3.6L VR6 | Cashmere Brown | Driver Assistance Package | Dynaudio | Discover Media | TPMS Direct | Side Assist | Adaptive Cruise | 3D colour cluster | More coming soon
    Genuine VCDS HEX-NET and VCP Pro
  6. #506
    Jan 2024
    canada
    Quote Originally Posted by MIG View Post
    yes it goes directly to the MIB
  7. #507
    Discover Media retrofit-screenshot-2024-05-24-121113-png
    Going back over your pictures, your adaptor does not looks to have wiring joining the rectangle plugs to the MIB, you need to remove this and move them to the other side of the adaptor.
    Just saw your reply, nvm then
  8. #508
    Jan 2024
    canada
    those wires are the can + and - that go through the adaptor to the MIB...so weather i connect them at that end or the MIB end, essentially it's the same thing
  9. #509
    kamold : Yes, I agree.
    However, and notwithstanding OP's belief that this is a low-line camera, the device DOES has CAN High/Low wires - which as you will know, is very much a characteristic of a high-line device on the OEM version camera.
    Why would a low-line camera need CAN wires? Low-line cameras simply need power and a trigger wire from the reverse-light to initiate the Video signal! This OEM camera has both the low-line trigger wire (item "3" in OP's picture) AND CAN wires - very odd!!!
  10. #510
    I have had one of these, it uses the steering angle sensor to approximate the high line lines, this is passive on the can network unlike the highline unit.
