In addition to the above, I tested with the original RNS-315 that came with the vehicle and the clock sync’s as expected.
Hi Kamold,
i just installed my MIB2 Pq std2 discovery media and i absolutely love it; way better then the slow RNS510 i had.
i purchased it from a fella that had a 2017 tiguan when he upgraded to a different unit.
long story short, i had someone set it all up for my car (2013 golf r with dynaudio sound), he removed the CP, wire harness, installed apple carplay, android auto, latetst firmware....etc
all works good, including michrophone...etc
the only issue i have is that i think he enabled the RVC (which currently i dont have, but i plan to buy a low res in the near future) and when i put the car in reverse i get the black screen as you should if you had a RVC.
HOW do i go about disabling that??? i have vagcom and could do that, but i'm not that tech savy with it and need some detailed info how to do it.
and then at a later date when i get a RVC i will probably need to enable back again
thanks in advance.
Byte 19 coding in 5f infotainment. Just turn off RVC low.
Sent from my SM-G781B using Tapatalk
@RBmk6R: I suspect @kamold is busy pursuing other stuff (we should allow him a personal life outside the forum- I guess!!).
Anyway, with my apology if I'm stealing his thunder - do this:
- Fire-up VCDS software, plug-in the dongle to the car's OBD port and connect to the laptop
- On the Main screen -click Select under Select Control Module
- Select
5F-Information Electr. module
- Click-on Coding - 07
- Click-on Long Coding Helper
- Use the UP/Down button to navigate to Byte 19. If you are using older VCDS software, click-on successive entries to the right on line 3) on the screen in Step 7. until Byte 19 shows
- Remove tick from Bit 4 on the screen below
- Press "X" at the extreme upper RHS of the screen - this should return to the screen in Step 5.
- The New coding box on the screen in Step 5. should be populated with the new long-code string
- Press Do it! and follow prompts to implement change
- Exit VCDS software
Thanks for the reply Don.
In this case I suspect that 5f is not enabled in the gateway, as it won't support that CAN address.
So at step 3. you'll need to manually enter the address 5F in the box at bottom left.
Then the rest of the instructions apply.
awesome thank you Don.
much appreciated.
