Hi to everyone! I recently retrofitted a Composition Media (5K7035200K) on my Golf 6 MY10 (replaced the RCD510). The unit has the hardware patch for the CP and in fact everything works except the voice commands.
However I have some small problems, I try to be brief.
1- The Composition Media has the ParkPilot active, but I do not have it installed in the car, so when I put the reverse gear the screen goes black and an error comes out after few time.
Unfortunately with the VAG I can't reach the 5F module (not even manually), I suppose the problem is the Gateway too old.
Are there other solutions, or am I forced to change Gateway?
2- The Composition Media clock does not synchronize with CDB and always remains at 0:00 (sometimes it appears as 6:28 and disappears after 1 second).
Is the problem always with the Gateway?
However the outside temperature is displayed correctly and on the CDB I see the song titles, radio channels, etc...
3- Sometimes, from the car speakers I hear a "pop": I notice it when I get into the car, shortly after opening the door. Has anyone had similar experiences?
Here is the scan with the VAG if it can be useful:
Code:
Thursday,17,September,2020,19:33:45:13314VCDS Version: Release 908.0
Data version: 20090911
Chassis Type: 1K0
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56 62 72 77
VIN:
01-Engine -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
77-Telephone -- Status: Not registered 0001
Address 01: Engine (J623-CFFB)       Labels: None
   Part No SW: 03L 906 018     HW: 03L 907 309 R
   Component: R4 2.0l TDI   H20 9978
   Revision: 42H20---    Serial number: 00000000000000
   Coding: 00190012042400080000
   Shop #: WSC 02203 264 00000
   ASAM Dataset: EV_ECM20TDI01103L906018 003014
   ROD: EV_ECM20TDI01103L906018.rod
No fault code found.
Readiness: 0 0 0 0 0
Address 03: ABS Brakes (J104)       Labels: None
   Part No SW: 1K0 907 379 AH    HW: 1K0 907 379 AH
   Component: ESP MK60EC1   H30 0107
   Revision: 00H30001
   Coding: 143B400D092400FF281202EA901B0042340000
   Shop #: WSC 00028 028 00001
Address 08: Auto HVAC (J255)       Labels: 5K0-907-044.clb
   Part No SW: 5K0 907 044 BS    HW: 5K0 907 044 BS
   Component: Climatronic   H15 0709
   Revision: 00003001
   Coding: 0000000002
   Shop #: WSC 00028 790 00209
   ASAM Dataset: EV_Climatronic A01006
   ROD: EV_Climatronic_VW36.rod
Address 09: Cent. Elect. (J519)       Labels: 1K0-937-08x-09.clb
   Part No SW: 1K0 937 086 C    HW: 1K0 937 086 C
   Component: BCM PQ35  M   103 0575
   Revision: 00103 AG
   Coding: 46180A3A90251AC040080081040089E443211588524D8160648000200000
   Shop #: WSC 02203 264 95663
   Part No: 1K1 955 119 F
   Component: Wischer 27011  21  0512
   Coding: 009795
Address 15: Airbags (J234)       Labels: 5K0-959-655.clb
   Part No SW: 5K0 959 655 D    HW: 5K0 959 655 D
   Component: AirbagVW10    037 0606
   Serial number: 003FKD043VJM
   Coding: 00003132
   Shop #: WSC 01383 790 00302
   ASAM Dataset: EV_AirbaVW10SMEVW360 A01011
   ROD: EV_AirbaVW10SMEVW360_VW36.rod
Address 16: Steering wheel        Labels: 1K0-953-549-MY9.lbl
   Part No SW: 1K0 953 549 CF    HW: 1K0 953 549 CF
   Component: J0527           056 0111
   Coding: 0000532
   Part No: 3C8 959 537 D
   Component: E221__MFL-TK6   H06 0022
   Coding: 00000226
   Shop #: WSC 00000
Address 17: Instruments (J285)       Labels: 5K0-920-xxx-17.clb
   Part No SW: 5K0 920 870 G    HW: 5K0 920 870 G
   Component: KOMBI         H03 0305
   Coding: 170900
   Shop #: WSC 00028 028 00023
   ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04052
   ROD: EV_Kombi_UDS_VDD_RM09_VW36.rod
Address 19: CAN Gateway        Labels: 1K0-907-530.lbl
   Part No SW: 1K0 907 530 AD    HW: 1K0 907 951
   Component: J533  Gateway   H07 0112
   Revision:   H07 01    Serial number: 280110F1002845
   Coding: E9807F06000202000002
3 Faults Found:
01300 - Control Module for Navigation with CD-Rom (J401)
            004 - No Signal/Communication
             Freeze Frame:
                    Fault Status: 01110100
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 168
                    Mileage: 139862 km
                    Time Indication: 0
                    Date: 2120.14.10
                    Time: 20:01:13
01044 - Control Module Incorrectly Coded
            000 -  -
             Freeze Frame:
                    Fault Status: 01100000
                    Fault Priority: 1
                    Fault Frequency: 42
                    Mileage: 139862 km
                    Time Indication: 0
                    Date: 2120.14.10
                    Time: 19:57:12
02874 - Control Module 2 for Central Convenience (J773)
            004 - No Signal/Communication - Intermittent
             Freeze Frame:
                    Fault Status: 00100100
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 208
                    Mileage: 139862 km
                    Time Indication: 0
                    Date: 2120.14.10
                    Time: 20:16:29
Address 25: Immobilizer (J334)       Labels: None
   Part No SW: 5K0 953 234     HW: 5K0 953 234
   Component: IMMO          H03 0305
   Serial number:
   Coding: 000000
   Shop #: WSC 00000 000 00000
   ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03005
   ROD: EV_Immo_UDS_VDD_RM09_VW36.rod
Address 42: Door Elect, Driver        Labels: 1K0-959-701-MIN3.lbl
   Part No SW: 5K0 959 701 D    HW: 5K0 959 701 D
   Component: Tuer-SG         009 2139
   Coding: 0000180
Address 44: Steering Assist        Labels: 1Kx-909-14x.lbl
   Part No: 1K0 909 144 J
   Component: EPS_ZFLS Kl. 70     3001
   Revision: 00H17000
Address 52: Door Elect, Pass.        Labels: 1K0-959-702-MIN3.lbl
   Part No SW: 5K0 959 702 D    HW: 5K0 959 702 D
   Coding: 0000180
Address 56: Radio
Cannot be reached
Address 62: Door, Rear Left        Labels: 1K0-959-703-GEN3.lbl
   Part No SW: 5K0 959 703 C    HW: 5K0 959 703 C
   Component: Tuer-SG         007 2101
   Coding: 0000144
   Shop #: WSC 00028 028 1012545
Address 72: Door, Rear Right        Labels: 1K0-959-704-GEN3.lbl
   Part No SW: 5K0 959 704 C    HW: 5K0 959 704 C
   Coding: 0000144
Address 77: Telephone
Cannot be reached
End   ---------------------------------------------------------------------
Thanks
