Page 35 of 57 FirstFirst ... 25333435363745 ... LastLast
Results 341 to 350 of 567
Thread: Discover Media retrofit
  1. #341
    Jul 2020
    Netherlands
    What are "holidays"? Down here in Victoria they have been deleted from our memories!!!
    Maybe not te right word for it. I’m just trying to be positive and make the best out of it. Hopefully the COVID-19 thing goes away soon.
    Concerning the startup image, I used binary counting for that.
    I found a thread somewhere were bit 2 was selected with binary number 00000010. So I figured if I need bit 1, then I need to use binary number 0000001. That worked for me, no special badge now.
  2. #342
    Jul 2020
    Netherlands
    Byte 18 coding:
    00 standard
    01 hybrid (twin drive)
    02 GTD
    03 GTI
    04 BlueMotion
    05 E Golf
    06 R Line
    07 Golf R
    08 AllTrack
    09 GTE
    0C FAMILY
    0F Welcome to SKODA
    10 beats audio
    Dynaudio coding needs to have byte 11 set to 05.
    Also adaptation channel for amplifier set to active, with messagebus set to infotainment canbus.
    Maybe I did set it to 03 at first I don’t recall. What I do recall was me thinking I was blowing up my speakers. . Luckily everything works and personally the sound even sounds better than with the rcd510
    Btw, I know the phone menu works not as before in my mfd. I don’t mind that, but the audio menu disappeared, nothing to be done to get it back?
  3. #343
    Quote Originally Posted by jmd View Post
    Phone and nav menu just add 77 and 37 to gateway installation list even though they aren't there.
    Then MFD integration will work.
    Sent from my SM-G960F using Tapatalk
  4. #344
    Quote Originally Posted by Naimad View Post
    Hi Kamold.
    I have a 2007 R32 would like to Add the mob and a reversing camera. Would this be possible?
    Would you be able to supply the parts and instructions?
    I am quite happy to pay! Also I’m in the UK. I don’t know if this changes anything?
    Thanks Damian
    I can put you in touch with someone a little closer to you who can assist
  5. #345
    Jul 2020
    Netherlands
    Phone and nav are present in the mfd, it’s the audio menu that is no longer there. When I’m connected with CarPlay and I’m using DAB I can’t see on the mfd which station I’m listening to. So I have to push the radio button to check the station and then back to CarPlay.
  6. #346
    Aug 2020
    London
    That would be very kind if you could. Thank you.
  7. #347
    Recently i (VW CC gen2) upgraded my factory fitted RNS510 to a new MiB2 PQ G version.
    Although everything works fine and as intended, i noticed the radio seems suffering from some very small hickups, random stutters in the menu animations, map drawing, especially zoom in/out is sometimes less fluent.
    It's not very noticeable, but i see quite a difference in performance when the unit is just fresh started and how it performs after 30 minutes. it. So for me, it only happens when the unit is running for a while.
    Initially i thought this was just a software flaw, something on the memory management that will become better after updates. And i just ignored it.
    Last week, after a long drive, i removed the unit from my car as i wanted to connect a USB extension.
    I discovered the unit was hot, very hot even. Could not hold the unit in my hands longer then 10 seconds, that hot.
    So i decided to open the unit, to see what kind of cooling is in there.
    Well... As for my G unit, it was even worse then i thought. On the bottom plate, there are 3 IC's (including the SoC) that are around 1 mm away from the metal housing, between there is some substance that i would rather call peanut butter, as it won't transfer thermal that much.
    So i decided to improve the chip thermal transfer. Removing that yellow/orange 'peanut butter' junk, replacing with a 1mm graphite CPU thermal pad, and to make sure the contact will be most optimum, i also added a very thin layer of a high-end thermal grease ( Noctua NT-H2 ).
    Also added this grease on the sound amp IC.
    And as the unit is almost empty from inside, i installed a 5mm laptop CPU fan, that just fits perfectly on the air holes of the unit, so it will blow out all the internal heat.
    Reassembled the whole thing, back into my car, and guess what.. Even after hours of drive, the unit is no more slowing down !
    In my conclusion, before, my unit was getting so hot, the internal SoC needed to do thermal throttling, reducing its performance.
    It's a relative easy modification, recommended to the ones who are experiencing degraded performance after a while as i did.
  8. #348
    Yes the thermal 'paste' they use is more like a terrible type of foam.
    Any time I have to open a unit up I scrape it all off and replace with CPU thermal paste such as Arctic Silver.
    Haven't ever needed to add a fan.
  9. #349
    Yes, initially i thought doing the same, just replace the standard thermal 'foam', but then i discovered there is a 1mm gap, at least on my G unit.
    Gap is just too big for any paste to efficient transfer any heat, so i decided to use (graphite) thermalpads to compensate the big gap.
    Any thin 1mm piece of copper would be fine as well, as long both sides have any thermal paste to improve the termal conductivity.
    I don't know if other models have the same 'gap'.
    The fan should not be needed indeed, i just add it, because i had it laying around my desk here anyways, and there was room for it.
    On some very hot days, it could help, as there isn't much passive cooling in that area anyways.
  10. #350
    Hi to everyone! I recently retrofitted a Composition Media (5K7035200K) on my Golf 6 MY10 (replaced the RCD510). The unit has the hardware patch for the CP and in fact everything works except the voice commands.
    However I have some small problems, I try to be brief.
    1- The Composition Media has the ParkPilot active, but I do not have it installed in the car, so when I put the reverse gear the screen goes black and an error comes out after few time.
    Unfortunately with the VAG I can't reach the 5F module (not even manually), I suppose the problem is the Gateway too old.
    Are there other solutions, or am I forced to change Gateway?
    2- The Composition Media clock does not synchronize with CDB and always remains at 0:00 (sometimes it appears as 6:28 and disappears after 1 second).
    Is the problem always with the Gateway?
    However the outside temperature is displayed correctly and on the CDB I see the song titles, radio channels, etc...
    3- Sometimes, from the car speakers I hear a "pop": I notice it when I get into the car, shortly after opening the door. Has anyone had similar experiences?
    Here is the scan with the VAG if it can be useful:
    Code:
    Thursday,17,September,2020,19:33:45:13314VCDS Version: Release 908.0
    Data version: 20090911
    Chassis Type: 1K0
    Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56 62 72 77
    VIN:
    01-Engine -- Status: OK 0000
    03-ABS Brakes -- Status: OK 0000
    04-Steering Angle -- Status: OK 0000
    08-Auto HVAC -- Status: OK 0000
    09-Cent. Elect. -- Status: OK 0000
    15-Airbags -- Status: OK 0000
    16-Steering wheel -- Status: OK 0000
    17-Instruments -- Status: OK 0000
    19-CAN Gateway -- Status: Malfunction 0010
    25-Immobilizer -- Status: OK 0000
    42-Door Elect, Driver -- Status: OK 0000
    44-Steering Assist -- Status: OK 0000
    46-Central Conv. -- Status: OK 0000
    52-Door Elect, Pass. -- Status: OK 0000
    56-Radio -- Status: OK 0000
    62-Door, Rear Left -- Status: OK 0000
    72-Door, Rear Right -- Status: OK 0000
    77-Telephone -- Status: Not registered 0001
    Address 01: Engine (J623-CFFB)       Labels: None
       Part No SW: 03L 906 018     HW: 03L 907 309 R
       Component: R4 2.0l TDI   H20 9978
       Revision: 42H20---    Serial number: 00000000000000
       Coding: 00190012042400080000
       Shop #: WSC 02203 264 00000
       ASAM Dataset: EV_ECM20TDI01103L906018 003014
       ROD: EV_ECM20TDI01103L906018.rod
    No fault code found.
    Readiness: 0 0 0 0 0
    Address 03: ABS Brakes (J104)       Labels: None
       Part No SW: 1K0 907 379 AH    HW: 1K0 907 379 AH
       Component: ESP MK60EC1   H30 0107
       Revision: 00H30001
       Coding: 143B400D092400FF281202EA901B0042340000
       Shop #: WSC 00028 028 00001
    Address 08: Auto HVAC (J255)       Labels: 5K0-907-044.clb
       Part No SW: 5K0 907 044 BS    HW: 5K0 907 044 BS
       Component: Climatronic   H15 0709
       Revision: 00003001
       Coding: 0000000002
       Shop #: WSC 00028 790 00209
       ASAM Dataset: EV_Climatronic A01006
       ROD: EV_Climatronic_VW36.rod
    Address 09: Cent. Elect. (J519)       Labels: 1K0-937-08x-09.clb
       Part No SW: 1K0 937 086 C    HW: 1K0 937 086 C
       Component: BCM PQ35  M   103 0575
       Revision: 00103 AG
       Coding: 46180A3A90251AC040080081040089E443211588524D8160648000200000
       Shop #: WSC 02203 264 95663
       Part No: 1K1 955 119 F
       Component: Wischer 27011  21  0512
       Coding: 009795
    Address 15: Airbags (J234)       Labels: 5K0-959-655.clb
       Part No SW: 5K0 959 655 D    HW: 5K0 959 655 D
       Component: AirbagVW10    037 0606
       Serial number: 003FKD043VJM
       Coding: 00003132
       Shop #: WSC 01383 790 00302
       ASAM Dataset: EV_AirbaVW10SMEVW360 A01011
       ROD: EV_AirbaVW10SMEVW360_VW36.rod
    Address 16: Steering wheel        Labels: 1K0-953-549-MY9.lbl
       Part No SW: 1K0 953 549 CF    HW: 1K0 953 549 CF
       Component: J0527           056 0111
       Coding: 0000532
       Part No: 3C8 959 537 D
       Component: E221__MFL-TK6   H06 0022
       Coding: 00000226
       Shop #: WSC 00000
    Address 17: Instruments (J285)       Labels: 5K0-920-xxx-17.clb
       Part No SW: 5K0 920 870 G    HW: 5K0 920 870 G
       Component: KOMBI         H03 0305
       Coding: 170900
       Shop #: WSC 00028 028 00023
       ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04052
       ROD: EV_Kombi_UDS_VDD_RM09_VW36.rod
    Address 19: CAN Gateway        Labels: 1K0-907-530.lbl
       Part No SW: 1K0 907 530 AD    HW: 1K0 907 951
       Component: J533  Gateway   H07 0112
       Revision:   H07 01    Serial number: 280110F1002845
       Coding: E9807F06000202000002
    3 Faults Found:
    01300 - Control Module for Navigation with CD-Rom (J401)
                004 - No Signal/Communication
                 Freeze Frame:
                        Fault Status: 01110100
                        Fault Priority: 2
                        Fault Frequency: 1
                        Reset counter: 168
                        Mileage: 139862 km
                        Time Indication: 0
                        Date: 2120.14.10
                        Time: 20:01:13
    01044 - Control Module Incorrectly Coded
                000 -  -
                 Freeze Frame:
                        Fault Status: 01100000
                        Fault Priority: 1
                        Fault Frequency: 42
                        Mileage: 139862 km
                        Time Indication: 0
                        Date: 2120.14.10
                        Time: 19:57:12
    02874 - Control Module 2 for Central Convenience (J773)
                004 - No Signal/Communication - Intermittent
                 Freeze Frame:
                        Fault Status: 00100100
                        Fault Priority: 2
                        Fault Frequency: 1
                        Reset counter: 208
                        Mileage: 139862 km
                        Time Indication: 0
                        Date: 2120.14.10
                        Time: 20:16:29
    Address 25: Immobilizer (J334)       Labels: None
       Part No SW: 5K0 953 234     HW: 5K0 953 234
       Component: IMMO          H03 0305
       Serial number:
       Coding: 000000
       Shop #: WSC 00000 000 00000
       ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03005
       ROD: EV_Immo_UDS_VDD_RM09_VW36.rod
    Address 42: Door Elect, Driver        Labels: 1K0-959-701-MIN3.lbl
       Part No SW: 5K0 959 701 D    HW: 5K0 959 701 D
       Component: Tuer-SG         009 2139
       Coding: 0000180
    Address 44: Steering Assist        Labels: 1Kx-909-14x.lbl
       Part No: 1K0 909 144 J
       Component: EPS_ZFLS Kl. 70     3001
       Revision: 00H17000
    Address 52: Door Elect, Pass.        Labels: 1K0-959-702-MIN3.lbl
       Part No SW: 5K0 959 702 D    HW: 5K0 959 702 D
       Coding: 0000180
    Address 56: Radio
    Cannot be reached
    Address 62: Door, Rear Left        Labels: 1K0-959-703-GEN3.lbl
       Part No SW: 5K0 959 703 C    HW: 5K0 959 703 C
       Component: Tuer-SG         007 2101
       Coding: 0000144
       Shop #: WSC 00028 028 1012545
    Address 72: Door, Rear Right        Labels: 1K0-959-704-GEN3.lbl
       Part No SW: 5K0 959 704 C    HW: 5K0 959 704 C
       Coding: 0000144
    Address 77: Telephone
    Cannot be reached
    End   ---------------------------------------------------------------------
    Thanks
