Looks like there's a technosat YD7 for sale at $270 in Brisbane on facebook. I believe these are hackable with some hardware mod?
132TSI Tiguan Allspace
Oké the strange thing is that the offroad menu the think blue trainer and parkpilot menu works fine also the drivingschool functie and mfa info works. Vehicle menu and performance doesn't work. I have update my gateway bc to bl but there is no change. The 3aa A bcm to R.
I think the menu,s are missing som puls.
This looks fantastic and a massive upgrade on RNS510.
Are you still able to kindly point to where I can get all the necessary parts to have this working?
I've got a 2008 MKV GTI, no RVC, no parking sensors
Hello ,
I reuse the original VW low camera with an RGB / CVBS « aliexpress « converter.
As you told somewhere in this thread I connect the « detect » wire to 12V and now I have the rear image on the DM.
But a really very bad image , moving up and down etc..
What is faulty ?
The adapter ?
NTSC/PAL option to change in Rear camera module ?
—> But another strange thing : VCDS can’t access to module 6C « rear camera « .
What can I do to recover access to it ?
thanks
Regards
RVC low has no 6C control module.
The converters are pretty poor quality.
Your best bet is to replace the RGBS camera with a CVBS camera. Then no converters involved.
Ok, can i reuse the existing wire , plug the new composite cam and "rearange" the cable for the new camera or do i need to do a complete new wiring ?
Can you advise me a camera that's fit for Touran 2013. There is so much model , sometimes one detail make the product incompatible.
Thanks
I found this one , is it ok ?
€ 14,10 23% Off | CCD HD Car Reverse Cam Trunk Handle Car Parking Rear View Camera Case for Audi/VW/Passat/Tiguan/Golf/Touran/Jetta/Sharan/Touareg
CCD HD Car Reverse Cam Trunk Handle Car Parking Rear View Camera Case for Audi/VW/Passat/Tiguan/Golf/Touran/Jetta/Sharan/Touareg - AliExpress
You can get good aftermarket cameras with proper dynamic guidelines from steering angle data.
Sent from my SM-G960F using Tapatalk
