Results 1 to 10 of 580
Thread: Discover Media retrofit
    Sep 2019
    Netherlands
    I already wrote a reply, but it needs to be confirmed by a moderator?
    Ok, i edited this post for now:
    You need ODIS S to run RVC calibration routine, as well as the calibration board. It will not complete with the older revision of camera.
    Much easier is to just use an aftermarket camera that doesn't require calibration.
    What exactly are your coding/adaptation settings for amplifier?
    Hello kamold,
    regarding Dynaudio here's my setup:
    Byte 4-7 - AA000000 2 Channels / 4 Passive Speakers installed (PR-8RH) or Sound system (PR-9VE)
    Byte 11 - 03 External Sound System installed (PR-9VE)
    ENG122229-ENG117764-Car_Function_List_BAP_Gen2-Amplifier_0x2D => activated
    ENG122229-ENG117765-Car_Function_List_BAP_Gen2-Amplifier_0x2D_msg_bus => Databus Infotainment
    MAS00950-Audio Parameter => 0
    ENG117919-Startup_Screen_Sticker_HMI => 00 02
    On my car's sticker there is "PR-9VE" noted (I ordered Dynaudio from factory). My amp is 5K0 035 456 C / KonzernAmp 8K H07 0202. I'm missing the sound "dynamics" a bit. The RNS 510 was way better regarding the sound.
    In your entry post you wrote:
    "Address 5F, long coding, byte 11 - change from 01 to 03 (or 05 for original Dynaudio amp)"
    Do I need to change byte 11 to 05 maybe? VCDS is missing that label though, only 01 and 03 is shown, but ofcourse one can enter it manually.
    With my current setup: balance/fader is shown correctly and it works as expected.
    And does anyone have experience with a converter for the original highline RVC? I'm thinking about trying one out (although I already ordered the the RVC module + RVC camera + harness).
    VW Tiguan 5N - 2014 - and still happy :o)
